Old 04-15-2013, 06:09 PM   #11
Jehyatt00's Avatar
Originally Posted by Dave_Monica View Post
Best to check the battery voltage...should be around 12.7 V if fully charged and 13.5V if plugged into shorepower and the converter is charging. If you have no 12V lighting without shorepower the battery is dead or disconnected. If you don't have a battery disconnect switch, check for an in-line fuse or resettable circuit breaker close to the battery.
Right on point with your help Dave. Thanks again.
Jehyatt00 is offline   Reply With Quote
