Old 11-16-2018, 11:32 AM   #1
Best Shower Head
I just picked up a 19 Alpha Wolf and the shower head leaks pretty bad when you push the button. Not worth trying to take it back for a warranty deal, I will just buy a new one. What is the best one out there you guys like?
thanks
Chris
ChrisMoore is offline   Reply With Quote
Old 11-16-2018, 11:38 AM   #2
You'll get a LOT of responses for the Oxgenics brand shower head.
Neither the DW or I liked our Oxgenics so we gave it away and bought a cheap R/V head off Amazon that works well, doesn't have a stiff hose and doesn't flow as much water as the Oxgenics. Besides 'best' is subjective. Just because it's 'best' for you doesn't mean it's 'best' for everyone else.
BTW... dribbling from the shower head is a GOOD thing in an R/V... it will keep you from being scaled or frozen when turned back on full.
Days Camped: '16=46 '17=30 '18=51 '19=10
Old 11-16-2018, 11:40 AM   #3
PPST Wannabe
kenandterry's Avatar
Oxygenics!!!!!!!!!
https://oxygenics.com/products/bodyspa-rv/
Drop the 🎤
Enuf said on this one......just watch.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-16-2018, 12:21 PM   #4
Fulltime family RVer
I’ve had an Oxygenics Body Spa and an Ocygenics Fury. The Spa “boosts” water more than the fury but the fury has multiple spray patterns. We’ve stuck with the Fury.
I also tried a couple of Eco Camel heads and hated them both.
Old 11-16-2018, 12:43 PM   #5
NMWildcat's Avatar
We have had the best shower experience with the standard, one spray pattern, Oxygenics. If you have an on demand tankless water heater, Oxygenics is a must.
If you don't like the supply hose that comes with your shower head, replace it with whatever hose you like. Connections are all fairly standard.
While you are upgrading your shower experience look at the Shower Miser system. We have one and absolutely love it. Great for saving water and making sure your shower is always warm without wasting water. Also a secondary way to fill your fresh tank if at hookups.
http://www.trailerlife.com/rv-gear/g...y-showermiser/
Scott and Liz - Southern NM
Old 11-16-2018, 12:49 PM   #6
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I (and my wife too, of course) was a solid believer in the original Oxygenics shower head, we had ours for 5 years. Our RS came with a 'generic' shower head which is much better, especially on the spray setting in combination with a shower valve to turn the water flow down to a trickle if we want to without affecting the water temperature.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 11-16-2018, 12:50 PM   #7
thanks
Chris
I am told it leaks to maintain temperature.
SquiggyFreud is offline   Reply With Quote
Old 11-16-2018, 12:56 PM   #8
NMWildcat's Avatar
Correct. That's the idea, works well with standard WHs, but doesn't work for tankless. Another reason we installed the Shower Miser diverter valve.
Old 11-16-2018, 12:59 PM   #9
Well, more like selling a flaw as a feature bec. it never worked for us .
Old 11-27-2018, 09:05 PM   #10
So i got and oxgenics head. The main reason for a new head is the trickle. I don’t want it. This new one still trickles. Plan to send it back. Any way to stop this? Or other ideas?
show, shower
