Old 06-15-2012, 03:03 PM   #11
BigTJohn's Avatar
This is what I use and works great. Click image for larger version
ID:	15300I have not towed with bikes on rack, would remove spare tire first.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 07-13-2012, 01:53 AM   #12
Rsgtivr6's Avatar
We are going to be loading 3 bikes on the back rack, 1 24" kids BMX and 2 28" adult mountain bikes. It looks like the main grunt of the weight is kept to the frame side of the bumper via the brackets and pins, has this been your observation BigT? It says it can hold 250 lbs plus the tire, so I am wondering if I can still leave the tire on with the 75lbs (guesstimated) of bikes and be ok. There has been a lot of talk about removing the spare regardless.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 07-13-2012, 07:23 AM   #13
jtstromsburg's Avatar
We have had two kids bikes (16-24") on it with our two large mountain bikes, plus the spare stays, no problems yet. The Weeks all look good and there has been no cracking of paint or any other sign of failure. My wife had followed me three different times and says the bikes are solids and don't bounce at all. I think that's key, to keep them tied down well.
Joel
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-13-2012, 07:34 AM   #14
Rsgtivr6's Avatar
Do you do anything special to secure them? I am thinking of picking up 6 1/4-20 u bolts to bolt them down.
Old 07-13-2012, 12:13 PM   #15
I use four or five REALLY REALLY special bungee cord straps
cheap but so far so good. I may make the wheel holder style show earlier in this post but for now just prop them all up against the verticle bar.
Joel and Teresa
2016 Sabre 34TBOK
Old 07-14-2012, 12:11 PM   #16
BigTJohn's Avatar
Rsgtivr6- You should have no problem with the weight as long as it is NOT in a "moment arm". That is the weight moving against or with the lever (which is the rack) while being held by the pins. If the tire is removed, the majority of the weight is lessened and the stress is reduced on the mounting system of the rack. A small dip in the road, and as you travel there are at least 100 in a mile, will increase the weight of the rack by at least twice or more. Many of those while loaded to max 250, will result in a catastrophic failure at some point. I remove the spare and stow in the bed of the TV and have lots of room w/o the bikes in the bed. Just my opinion.
Brenda and John
bike
