Originally Posted by Mmanning
I have a serious leak when I tried to use my water pump. Flooded my bathroom floor from the back by my water heater. I like the idea of taking that potion of the underbelly down. Does this sound like a plan to check my water pipes in the back?
Originally Posted by Toby
Isn’t all that above the floor though? Both my hwh and water pump are hidden away behind panels and above the floor.
I'm not sure. Just had water coming from underbelly too so assumed the pipes were leaking or broken under there somewhere. Trying to figure the best way to repair without taking this to a shop!
Plumbing supply lines are typically inside the R/V and drains pipes and tanks are below floor. If it flooded your floor, it likely flooded down into the underbelly.
You didn't mention if your leak while using the water pump is something new or this just happened. Had it worked OK previously? Do you live where you need to winterize?
Too many variables for us to give you much advice.
