Old 08-22-2011, 10:37 PM   #1
breaker question for those of you with a cherokee (around 2006 model)
i dont know how many cherokee models have the same converter in them, but i have an 06 wolfpack with a 50amp converter. it is a parallax power supply model 555. if you have this setup, what is the very top breaker for on your converter? i have a 20 amp breaker there that is not label and i cannot figure out what its for...
2006 Cherokee Wolfpack 295WP - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Starlight Revolution 300 lumen LEDs EVERYWHERE!
2012 Dodge 2500 - deleted and tuned by H&S performance
Bocephus is offline   Reply With Quote
Old 08-22-2011, 10:43 PM   #2
skgeorgy's Avatar
My best guess would be your Air Conditioner. Usually most other devices and branch circuits will be on a 15 amp breaker.
Stephen Georgy
2011 Lacrosse 318BHS
2006 F-350
[SIGPIC]
skgeorgy is offline   Reply With Quote
Old 08-22-2011, 11:02 PM   #3
no, that breaker is labeled. i have the AC, microwave, water heater, general, main, GFI, and then this random breaker on top. i may just have to unplug the ac power and start pulling it apart. maybe nothing is even hooked up to it
Old 08-22-2011, 11:13 PM   #4
skgeorgy's Avatar
My next guess from left field would be your electric lift. However that more than likely runs off DC power.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-22-2011, 11:36 PM   #5
yeah i know the front jacks are DC. i do have a table that lifts up and down in the rear toy hauler garage area, but that works without being leashed up to AC, so it cant be that either. hmmmm
Old 08-23-2011, 12:03 AM   #6
skgeorgy's Avatar
My brain hurts from thinking. Can't imagine how yours is.
Stephen Georgy
2006 F-350
[SIGPIC]
Old 08-23-2011, 12:11 AM   #7
jimh's Avatar
are u wired for a second ac?
jimh is offline   Reply With Quote
Old 08-23-2011, 04:39 AM   #8
i have no idea. how could i tell? i guess it would make sense due to the 50 amp service and only 1 AC unit on board...
Old 08-23-2011, 05:28 AM   #9
Herk7769's Avatar
I believe Jim is correct.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-23-2011, 06:20 AM   #10
So how can I figure out if that's indeed what it's for? I was going to pull the front panel of the converter off and see if there were any wires going to it, but if it's prewired then I'd imagine everything is already hooked up and looks normal...
Old 08-23-2011, 06:27 AM   #11
Herk7769's Avatar
I believe that a pre-wired unit also has the roof penetration pre-cut.
Is there a vent or skylight in the bedroom?
More than one vent?
Remove the interior trim ring(s) and look for a wire bundle that is taped off.
I don't have a 2 AC unit so maybe someone who does can help you more.
Old 08-23-2011, 06:30 AM   #12
jimh's Avatar
if u have a blank electrical face plate in the ceiling next to the forward 14X14 crank up vent...skylight. u r prewired for a second air conditioner. if so, they installed the breaker in the box.
the blank plate in the ceiling on mine had a label on it (a much older trailer didn't).
makes life easy if u should ever decide to install a second air conditioner.
Old 08-23-2011, 10:47 PM   #13
i do have a large skylight in the rear of the camper...in the garage area, but no other irregular looking ceiling panels. i did pull of the front "protective" cover around the breakers. there are no wires going into the breaker i was inquiring about. i guess i could have done that in the first place.....but i dont like taking things apart that arent broken
breaker
