Old 04-19-2019, 04:51 PM   #1
Cable booster problem
Hi all,
I ran into a problem with the wall plate booster. I push the button and the green light flickers then turns off. I removed plate and disconnected one cable line the green light turns on. But when I connect it back it turns off. I did replace the 15amp fuse that was blown. Prior to this it been working fine like itís supposed to. Any ideas, thoughts or as to why this cable line shorts it. Does the wall plates go bad? Thanks
leonards is online now   Reply With Quote
Old 04-19-2019, 04:51 PM   #2
Some pics Click image for larger version
ID:	202218Click image for larger version
Old 04-19-2019, 05:16 PM   #3
Just as confused as you
Scrapper's Avatar
I had a problem with my OTA booster a couple years ago. I was loosing signal from the antenna as long as the plate was in the wall. When I took the plate and let it lay where the coax cables were in line with the connectors it would work fine. There was a problem with the solder joints or printed circuits. I replaced the booster and all is well. You can get the booster plate from Camping World or any RV dealer. Mine has the Satellite and TV connections and because no one in my area had the same one I needed I had to get mine from Amazon. BTW, that booster is a power injector/splitter/cable TV bypass. The amplifier/booster is in the antenna head on the roof.
Name:	WallPlate LED & Switch.jpg
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 04-20-2019, 05:21 PM   #4
Head Rambler
Do you know which coax you removed?
It's possible that the antenna booster is shorted in the antenna if that's the coax you removed.
Gotta go campin!
Old 04-20-2019, 08:21 PM   #5
After looking online and schematics of the coax. The cable I removed was the one going to the antenna. So does that mean the antenna is bad? Or the face plate went bad? Is that called the booster?
Old 04-20-2019, 09:13 PM   #6
Scrapper's Avatar
The actual amplifier or booster is in the antenna head on the roof. The circuit board on the wall plate is a combination power injector/splitter/cable TV bypass.
As Bama Rambler said the coax could be shorted at the antenna head or may be even a bad crimp on the coax at the antenna head or the injector board. If you have access to another coax long enough to from reach the antenna down through the door to your injector board you can try to see if you get good reception.
My guess would be a bad crimp on the coax connector on either end of the cable as it is a common problem with coax cables.
Richard & Jill
Old 04-20-2019, 09:52 PM   #7
bubbles's Avatar
Here is an excerpt from the Winegard manual for a wall plate power supply. May be applicable.
RV WALL PLATE/ POWER SUPPLY
This unit is equipped with a polyswitch, (current limiting device), which will shut down +12VDC if there is a direct short between antenna and power supply. Green indicator light will not light. Once short is eliminated, device will reset itself in approximately 2 minutes.
Old 04-20-2019, 10:46 PM   #8
Denver To Yuma In 90 Days
I found that my Furrion AM/FM/CD/DVD player/receiver antenna wire was coaxed in to the roof TV antenna through a splitter inside the entertainment center.
It was shorting out the signal and the instant I unhooked it from the spitter...
I had picture back!
Worth checking out if the other stuff doesn't work out.
JohnD10 is offline   Reply With Quote
Old 07-24-2019, 08:44 PM   #9
Is removing the frisbee easy? Or Does it just unscrew from the base or do I need to break the seal?
Old 07-24-2019, 08:45 PM   #10
Frisbee looking antenna that is
Old 07-25-2019, 07:49 AM   #11
Head Rambler
It depends on the antenna you have. Most of them have retaining bolts or screws in the neck and you can take the top part off the base by removing those.
Do you know which antenna you have?
Gotta go campin!
Old 07-25-2019, 08:14 AM   #12
jeff64's Avatar
It would be real helpful if we knew what kind of rig you were running and the vintage!
The winegard antennas are a powered antenna and as such, you can and should read 12 vdc at the antenna connection ( from center wire to ground shield/nut) as well as the same voltage at the connection on the plate. On mine the coax, goes through the roof to a "union", another coax goes from there to the antenna. It's sealed to the TPO roofing with Dicor. If that connection has somehow loosened you won't get a signal. How do I know this? Use your voltmeter and wiggle the connections around. You do have a voltmeter don't you?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
cable
