Old 04-13-2017, 12:26 PM   #1
Exclamation Cautionary Tale: Wheelwell Caulking
All,
I just wanted to share a warning. Be sure to check that the factory caulked all of your exterior joints. This past weekend we discovered the hard way that the factory failed to caulk the joint between the exterior wall and the driver's side wheelwell. As a result, the recent rainstorms filled up the underbelly of our 16BHS up with water... Not fun! It is currently at the dealer once again, having something else fixed under warranty.
It looks like we caught it before too much damage was done, but there is definitely new insulation in our future.
ID:	134629   Click image for larger version
ID:	134630   Click image for larger version
jamessandberg is offline   Reply With Quote
Old 05-03-2017, 02:29 PM   #2
Yikes, that sucks. We keep ours covered and it hasn't been in the rain, but I will definitely check next time I'm over there.
https://cookeattravelrepeat.com
2016 Super Crew F150
2017 Cherokee Wolfpup 18TO
josheaton is offline   Reply With Quote
Old 05-03-2017, 02:31 PM   #3
Better than that.....while you're at it pull the wheel and take a good look up in the wheel well. I bet you do not like what you find. Before you do have some good caulk and a can of undercoating on hand.
Mr Havercamp is offline   Reply With Quote
Old 05-03-2017, 03:03 PM   #4
What year is yours? Ours is the 2017 18TO
Old 05-04-2017, 09:57 AM   #5
K2Kevin's Avatar
Thanks for the heads up. Just checked our 2017 Wolfpup 16BHS, looks all caulked up.
K2Kevin is offline   Reply With Quote
caulk, wheel
