Old 02-08-2015, 02:34 PM   #1
Cherokee 264L coax cable connections
We have a brand new 2014 Cherokee 264L. We have a Wingard Carryout satellite receiver. When we run the coax from the satellite through the door and directly into the back of the DirecTv box, everything works perfectly. When we run the coax from the satellite to the coax connector on the side of the trailer and then connect the DirecTv box to the wall coax connection by the TV mount, it will not acquire a signal. We have an antenna on the roof but no crank to do anything with it. The coax connection in the wall has a 12V outlet and a coax connection. What are we doing wrong? Appreciate any help as we are newbies at this. TIA
ROXY3591 is offline   Reply With Quote
Old 02-08-2015, 07:34 PM   #2
I have the same set up on Salem I just bought. I think that the coax connection by the TV is connected to the roof antenna.
J W Bowman is offline   Reply With Quote
Old 02-08-2015, 07:45 PM   #3
Flybob's Avatar
Is the button on the wall mount coax connector pushed in ( green light on). If so turn it off.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-08-2015, 08:17 PM   #4
FlyBob,
Is that connection to the roof mounted antenna ? What is the button/green light for ? What is the 12 volt outlet for?
Old 02-08-2015, 08:27 PM   #5
KD 1's Avatar
I have been told you will have to run another 'circuit'....install another receptical outside & inside.
I don't know all the answers but something about your receiver (next to the TV) sends power to the dish/carryout thing & if you run it through the existing connectors the power doesn't reach the outside.
A guy showed me this using a meter on the dish end.I was getting no power with the button in or out. I had to do as you said, rub it in thru the door
KD 1 is offline   Reply With Quote
Old 02-08-2015, 09:53 PM   #6
BooBoo23's Avatar
If you don't have an outside port marked "satellite" you may need to run a separate coax from the outside to a wall outlet on the inside. According to some of the others that have had only a "cable" port the solution was to change the splitter to one that is a different frequency. It MAY be located behind the wall outlet in the trailer. The splitter that they installed was purchased from Home Depot of $4. It is a "Ideal" splitter model #85-132, 5mhz to 2.3ghz. If you do a search on the forum you may find the thread that discussed it. The problem with the "cable" port is that it will not pass the 12V needed to power the antenna. You should also turn off the antenna amplifier.
The TT I have has two outside ports, one for cable and the other for satellite and two inside wall outlets, one for satellite and the other for cable/OTA television.
I can't remember if I saw the discussion on this forum or a different one so do a few searches (on the menu bar at the top of the page) and maybe you can find the solution.
One other method is purchase a "flat" coax jumper, you can get them on Amazon for about $4 + shipping or Walmart.com for about $2 and if shipped to pick up at the store there is no shipping charge. That will allow you to close a door or window with the coax passed through. That is the quick easy way to solve the problem
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 02-09-2015, 01:24 PM   #7
Thanks, everyone. You have given me some good information and I am going to check it out!
cherokee
