Originally Posted by carbuthn
You mean that the motors burn up to protect the fuses?
I normally have my RV fairly level and have not had any issues with operating the slides, they do not appear to have excess loading.
It could be a problem if you put a couple hundred pounds of food in the pantry, but if the fuses are sized correctly they should protect the motors.
The guy who told me this story just said the motor burned up because of an overload on the slide out as a result of the RV not being level.
You make a good point a fuse should have blown and saved the motor unless there is no fuse to the motor.
Thanks.
