Old 04-14-2011, 10:10 PM   #11
kmzad's Avatar
Thanks!
Well, if you remove the plastic skylight framing in the ceiling, you can access the wires to the light and the fan. The trick is getting behind the wall. I very carefully removed the 1" molding at the ceiling on the wall that is stapled in. I drilling angles up and down behind this molding and fished the wires behind the wall. I wired in a fan/light "in line" switch I bought on ebay for $14. I then put the molding back making sure to use the same staple holes. You can't tell it was removed and the holes I drilled are completely hidden behind the molding...
kmzad is offline   Reply With Quote
28bh
