Old 10-10-2007, 11:27 AM   #11
Dodge Guy's Avatar
Mine is a 32B it weighs 7200lbs empty and approx. 8600lbs ready to travel. I tow with an 02 Excursion V-10. tows it just fine. the Cherokee Lite line is lower profile than the the standard TT`s, which is what I have. 11'6" compared to 10'6" the lower profile will make a difference when towing especially for MPG and the lower side profile will make a little difference in windy conditions. we used to have the 28A 6500lbs ready to travel, and towed it with a 97 Dodge conv. van with a 5.9 and 3.90 gear.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-10-2007, 11:54 AM   #12
RAC
With the V-10 you get about 10,100 lbs of pulling power which is under the GVWR for the trailer he has selected.
RAC is offline   Reply With Quote
Old 10-10-2007, 01:00 PM   #13
steveqvs's Avatar
okay again thanks to all. Another question... dealer is selling hard the Choice Plus extended warrenty. 7 year, says you can take it to any dealer. Anybody think these are worth it? I am not a super handy guy more of an office / computer guy.
steveqvs is offline   Reply With Quote
Old 10-10-2007, 01:12 PM   #14
How much?
I didn't buy an extended warrenty on mine but I prefer to fix and modify stuff myself. But it may bring a piece of mind to you. Shoud a fridge go south you're looking at a couple of grand to get one replaced. That in itself may make the warrenty worth it.
greg
aintgotnun is offline   Reply With Quote
Old 10-10-2007, 01:24 PM   #15
RAC
Standard is one year, then FR overs an additional for a hundred bucks.....
7 years bumper to bumper??? That sounds like a pretty penny.
Old 10-10-2007, 02:15 PM   #16
steveqvs's Avatar
Yes 7 years bumper to bumper $1300. My first reaction was no, but since the unit has slideouts, i started wondering if it was a deal. I didn't know about the $100 for an additional year from FR..... thats an idea too. But i am planning on owning this the 7 years if not longer... I hope that is.... it is my first.
steve
Old 10-10-2007, 02:34 PM   #17
RAC
Personally, anything that goes wrong, I can fix. The major structural components are covered for like 12 years, so for me, the 1300 bucks wouldn't happen. that's a LOT of beer!
Old 10-20-2007, 11:06 PM   #18
budfans's Avatar
I have a 2007 285B+ since the spring and this is what i found wrong with mine so far list of needed repairs, they are as follows --------
Paneling on dinette is scratched ( on order)
Seam sealer all over the outsides and around all futures and running down
Small stress crack in front nose
Low water pressure threw out trailer ( took hose off my camper and put on camper next to me and pressure was fine)
Toilet is not straight and low water pressure ( does not rinse bowl)
Sliding door to the bedroom fell off and hit my wife ( chips now on corners)
Wall that sliding door hangs on is bowed ( puts pressure on door )
Cabinet door to small pantry near back bedroom fell off
Wall next to microwave has scratches ( someone filled with putty)
Spare tire cover flew off on trip home after purchase and delivery
Chrome trim ring on wheels flew off
Rubber seal under main slide out fell off
Main slide has vibrations
Window shades in main slide at the dinette rear one is mounted crooked and the big window comes apart
Ceiling panel in main slide has bubbles
Bunk room door does not fit (opening to small)
TV shelf in bunkroom ( thin paneling 13" TV leg pocked thru it )
Draws in bunk room fall out and twist cross rail in cabinet
Cable hookup in bunk room does not work
Bunk slide does not fit flat to outside wall
Window shade in top bunk does not work right
Screen door is bowed
Entry door drags on screws
Front right storage door does not fit
Storage door locks don't work right some are hitting screws
Drain waste valves leek
Power converter has been running intermittently ( tap wall and it works)
When not in use battery runs down fast
PS this trailer looked like it never had dealer prep done . There was saw dust all over and more then half of nail holes were not wiped clean I spent two hours wiping the putty clean .
07 285B+ cherokee 5er
02 F350 power stroke c/c
budfans is offline   Reply With Quote
Old 10-21-2007, 09:15 PM   #19
steveqvs's Avatar
Its Here!
I got my 29b+ yesterday and we spent the night in it. Budfans, I am sorry you have had such bad luck. I can't believe we even have the same type or brand of camper. Mine arrived surprisingly with 2/3 full of of fresh water. It looked like everything was prepped. Everything worked. The only imperfection that I noted was the Cherokee word sticker on the front of the camper... the e is coming off. The only other strangeness we saw was all the drawers have glides except the one under the dinette bench. It was hard to pull out and it seemed not to have a guide. Not sure if that is normal or not. Other that that everything seemed to work well. I am new to campers so I probably might find things as we go on and I have lots of questions. I read the manual but it sure didn't seem to answer a lot of questions I had.
Steve
Old 10-21-2007, 09:37 PM   #20
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Ask questions anytime. Enjoy your new trailer.
Budfans...if it's any consolation, my Salem PT had putty all over the woodwork that I had to wipe down as well. None of the manufacturers are good at cleaning up the sawdust either.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
cherokee
