Old 07-17-2017, 12:37 PM   #1
Cherokee Grey Wolf 26DBH Dinette to Bed
While this issue is nowhere near as important as solving world hunger, I am stumped at trying to figure out what arrangement I should put the seat cushions from the dinette down in order to make the dinette into its intended sleeping surface. It seems no matter what order I put them, I end up with a little "hole" somewhere in the sleeping surface. Am I missing something obvious, or is this how it is supposed to be?
ID:	145050   Click image for larger version
justkdue is offline   Reply With Quote
Old 07-17-2017, 02:36 PM   #2
A32Deuce's Avatar
On mine, the seat bottoms and seat backs make up the padding. Nothing left standing.
A32Deuce is offline   Reply With Quote
Old 07-17-2017, 08:08 PM   #3
Leave the seats in place, pull the 2 cushions from the back wall and place them 1 above the other in the center. Give me about 15 minutes, I can run out and take a pic for you.
ProCharger is offline   Reply With Quote
Old 07-17-2017, 08:33 PM   #4
I ended up replacing the junk mattress pad that comes on the bed with a dynasty mattress 10" gel memory foam mattress so I took out the pad and trimmed it to fit in the bunk. You can use it on the bottom bunk but I doubt there is headroom on the top bunk. It also fits on the dinette....which I recommend otherwise the outside cushion tends to want to shoot out. You could swap it up to help and put the back row seat towards the front since it has more depth but it will still want to shoot out if you get in the crease. The pad eliminates that. It is missing the corner due to the bunk being angled but it is still functional. Hope that helps!
Old 07-17-2017, 10:43 PM   #5
Thanks ProCharger - I get the picture now
bed, cherokee, grey wolf
