Old 06-01-2011, 10:45 PM   #1
Unhappy Circuit Breaker
We have looked high and low and in between and cannot find the circuit breaker on a 2004 Cherokee Fith Wheel. Checked the manual and it does not show where it is located. Does anyone know where the breaker might be. The breaker kicked out and we need help. Thanks for any help.
Bowlking is offline   Reply With Quote
Old 06-02-2011, 06:19 AM   #2
KyDan's Avatar
If you are talking about the outlets not working one of them is a ground fault
outlet. The test/reset buttons are on one of your outlets. It controls the others.
I can't tell you where your fuse box is located. It should be in plain sight inside
somewhere!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 06-02-2011, 10:10 AM   #3
Circuit Breaker
Thank you for your suggestion, we will try that right away. If it doesn't work, off to the dealer.
Old 06-02-2011, 10:51 AM   #4
Oakman's Avatar
I don't have your make fifth wheel, but you should have a circuit breaker/fuse box that looks similar to the one in the picture below. It's the brown looking box under the fridge. Open it and you will find the fuses and breakers. Yours may not be by the fridge but it will probably be somewhere close to the floor.
If your GFI outlet needs to be reset, it will look like the one in the pic below. It will probably be located in a bathroom or wash bowl. Press the reset button.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-02-2011, 07:50 PM   #5
Thank you very much, this was a big help. We were able to locate it. We are newbies at this camping stuff.
Old 06-02-2011, 07:52 PM   #6
Circuit Breaker
All is good now. Found the circuit breakers due to the great suggestions.
breaker
