Old 10-03-2016, 07:19 AM   #1
Click sound before heat kicks on - 2014 Forest River
I recently purchased a 2014 Forest River 294BH. This weekend we turned on the heat. We noticed a clicking sound before the heat turned on. That clicking sound continued for about 30 seconds after the heat was on. It sounds like it's coming from the AC unit area. The camper was plugged in to electric. I didn't sound like it does when you're trying to light the stove. And the clicks weren't in the same repetitive loop.
What could this be? Everything seems to work, but it woke us up several times in the middle of the night so I just wanted to make sure it's all good.
Thanks!
jmwebguy is offline   Reply With Quote
Old 10-03-2016, 07:59 AM   #2
SeaDog's Avatar
what you are describing sounds to me like the spark ignition on the furnace.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-03-2016, 08:07 AM   #3
Flybob's Avatar
The furnace uses a direct spark ignition (DSI) vs the old pilot light. When heat is called for, the gas valve opens and the electronic igniter generates a spark to light the furnace. Much like the igniter on a gas grill Normal operation.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-03-2016, 08:13 AM   #4
Since the OP said the sound seems to be coming from the A/C unit, my guess is a relay in the control at the A/C unit.
Some of these units with Dometic digital thermostats have relays in the A/C that work in conjunction with the furnace to provide A/C fan when the furnace runs. It could possibly be that.
I wouldn't think it would be so loud it would wake you from a sleep though??
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 10-03-2016, 08:53 AM   #5
Head Rambler
Like 5Picker said, there are relays in the A/C control box. With the digital thermostat/control box, there's a relay for the furnace and a couple for the blower.
The furnace relay would click each time the t-stat calls for heat and the one for the A/C blower would also click if the fan is set to either hi or low. However they shouldn't be clicking more than once each time stat calls for heat.
There have been reports of this before and it wound up being a problem with the control box.
Gotta go campin!
Old 03-20-2017, 05:41 AM   #6
bhall5368's Avatar
Any updates on this issue? Mine is doing the same thing and it's annoying! Wakes me up every time.
bhall5368 is offline   Reply With Quote
Old 04-17-2017, 07:41 AM   #7
bhall5368's Avatar
By "control box", are you referring to the thermostat? I've read other posts concerning this and someone changed out their thermostat to resolve this problem.
Old 04-17-2017, 11:01 AM   #8
Head Rambler
The control box is the box in the A/C. It's behind the filter grill.
Gotta go campin!
Old 04-17-2017, 12:11 PM   #9
See below.
Yes, mine is the same thermostat and I don't have a heat strip in the A\C that the clicking sound comes out of. Here goes: Make sure the Single Zone LCD thermostat is in the Off condition. Press the "+" button and, while holding it, also press and hold the On/Off Mode button for 3 seconds. LCD will show --. Press the On/Off Mode button again to turn system off. This completes the initialization. The furnace On/Off temperature differential should be set at this time.
"Furnace"- Furnace Mode
In the FURNACE mode the system will cycle the RV's furnace On and Off based on the room air temperature and the temperature set-point on the Single Zone LCD thermostat. The system can be configured to operate using an On/Off differential of either 1 degree F or 2 degree F. This feature is programmed during the system initialization. To set the temperature differential the system must be Off. Press the "-" button and, while holding it, also press and hold the On/Off Mode button for three seconds. Release the On/Off Mode button. Then release the "-" button. Press the "+" button to toggle between "d1 and d2", "d1" for 1 degree F differential and "d2" for 2 degrees F differential.
When I did this originally I thought it would be better to have d1 as the setting. I still had the clicking. When I got fed up last weekend listening to the clicking I did the initialization again and this time I set if for d2. Don't know if that did the trick or just redoing the initialization again, but it worked with no more clicks. Hope this helps fix yours as I know what you are going through.
Norcalace is offline   Reply With Quote
Old 04-17-2017, 02:19 PM   #10
bhall5368's Avatar
Great! I will try this and post the outcome
Old 04-17-2017, 02:20 PM   #11
Iwannacamp's Avatar
Originally Posted by Norcalace View Post
See below.
You guys are good....
2017 Puma 297RLSS
Old 04-17-2017, 02:51 PM   #12
Same thing happened to me my first time out. Temp in the low 30s. Clicking from the AC box drove us nuts. Got home and hit the search on the forum. Did the initialization procedure and all was good. Nothing in my docs about it nor did the inept dealer know what to do. Crazy when you have to show dealers how to fix their products.
Old 05-17-2017, 02:24 PM   #13
This worked for me
darkskyseeker is offline   Reply With Quote
Old 09-16-2017, 06:44 PM   #14
strut526's Avatar
Had a couple freeze warnings in Michigan a few weeks ago. My neighbor has a 2015 trailer. Nothing but problems since they bought it brand new. This time it's the furnace. It worked fine in the spring. They turned it on last weekend and it started and cycled, then it cycled off. I checked to make sure she has prophane, checked fuses. Well, they looked fine to me. It is out of warranty, she does have an extended one. Her husband has MS, so he really can't figure it out. Any ideas on what i could check for them?
2005 American Sport -Went seasonal 2012 Irish Hills, Michigan
strut526 is offline   Reply With Quote
Old 01-07-2018, 05:52 PM   #15
bhall5368's Avatar
Sorry it's taken me so long to respond about this, but it just got cold here in Florida over the last few days and needed the heat. This worked like a charm!
2014, forest river
