Old 08-20-2018, 08:44 AM   #1
Cup holder wiring
Loose wire on the cup holders. Can anyone compare and let me know where this loose one belongs?Click image for larger version
Sarjent is offline   Reply With Quote
Old 08-21-2018, 06:34 AM   #2
SeaDog's Avatar
You might want to list your make and model so you get the correct answer. Wiring seems to be somewhat hap hazard on these rigs.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-21-2018, 07:08 AM   #3
My guess would be that it belongs in the crimp with the white wire. The other side....Black w/white stripe (usually the + positive side) is connected to the power/load side, so logic dictates that the solid black belongs with the white neutral/ground wire. I work with wiring like that everyday assembling laboratory equipment and all the cable we use just like that, the black with white stripe is always + positive.
TheWolfPaq82 is offline   Reply With Quote
Old 08-22-2018, 07:49 AM   #4
Thanks. All good now.
Old 08-22-2018, 08:02 AM   #5
I hate to ask, but I really want to know. What do cup holders use current for?
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 08-22-2018, 08:10 AM   #6
In my 2018 the cup holders each have USB ports and led ring lighting
Old 08-22-2018, 08:58 AM   #7
cduemmel's Avatar
Crimps
I really hate those type of crimps. They never seem to want to hold. Most of my electrical work I try to solder for strength, but that's just me. Also, in my defense, I haven't had to solder anything on the Trailer yet.
Chris & Susan
Greensboro, NC
2019 Grey Wolf 23MK Travel Trailer
2011 Ram 1500 Outdoorsman 4x4
2003 Harley Davidson Super Glide (solo seat)
cduemmel is offline   Reply With Quote
Old 08-23-2018, 07:03 AM   #8
We lost most of our 110V outlets last year on our new 2018 Cherokee due to those crappy push quick connects they use for wiring. Neutral fell out and took out all of the 110V outlets, except for the GFI ones.
Old 08-23-2018, 07:22 AM   #9
cduemmel's Avatar
When I find one of those that has failed, I just change the whole thing to either a solder on connection or a connector that I just clamp on and it makes contact through the insulation, depending of circuit voltage.
Chris & Susan
Greensboro, NC
Old 08-27-2018, 12:54 AM   #10
Ours havenít worked from day one they spent an hour messing with it before we took delivery and I need to take it back in to have them replace it under warranty. Not sure what the deal is.
nitis is offline   Reply With Quote
wiring
