Old 07-14-2011, 04:40 PM   #1
Decal Removal on stick and tin
Has anyone removed the decals from a stick and tin camper? We love the colors and most of the decals on our 2007 27Q ..except for the Wolf. Im thinking even if the decals are removed an outline will still be visible.
VAfan is offline   Reply With Quote
Old 07-14-2011, 04:58 PM   #2
Villa Estate 392FLFB
The_Stuff's Avatar
"goo-gone" works wonders.
to get the sticker off, use a hair dryer and peel it off.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-14-2011, 07:34 PM   #3
Iggy's Avatar
WD-40 will also do it.
Old 07-14-2011, 08:56 PM   #4
I do a lot of this type "sticker" work and I find that goo-gone is usually a little too aggresive for the paint on most trailers. The heat gun and a plastic scraper called "little chizller" seems to work best for me. Little chizller is available at maybe Signs Now or other sign companies. There is also availabe at auto parts stores a "vinyl eraser" wheel or disc that a lot of truckers use. Put it in your drill and "erase" the graphic. For removing the glue left after the vinyl is off, I like charcoal lighter the best. WD-40, cigarette lighter fluid, etc. Work good, but sometimes one will work better than the others. Mostly, you will need a lot of "elbow grease" to complete the job.
Hope this helps and good luck.
Mickey
Sawdr73 is offline   Reply With Quote
Old 07-14-2011, 10:50 PM   #5
flyrotor's Avatar
On a 2007 I think you are right, the different chemicals or methods as stated above will remove all the goo, but more than likely you will see a difference. The paint under the logo will will have minimal oxidation where the 4 years of exposure to the elements the paint will be faded and oxidated.
You might be able to minimize this by using some buffing compound and keeping it waxed
flyrotor is offline   Reply With Quote
Old 07-15-2011, 03:09 AM   #6
No matter what you do and or use you will always see some kind of outline etc. Thinks twice about it. As much as you may not like it the end result may be worse
Fourn3833 is offline   Reply With Quote
Old 07-15-2011, 09:10 AM   #7
trudinator's Avatar
what's wrong with the wolf? What did he (she?) ever do to you?
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 07-15-2011, 04:37 PM   #8
The thing is howling all night! J
Old 07-15-2011, 08:53 PM   #9
trudinator's Avatar
Hahahahahahahahah!!!
