Old 06-22-2018, 07:19 AM   #1
Dehumidifier added
For anyone concerned about humidity levels either when the TT is stored or in use, I would recommend this little unit by Perfect Air. Itís doing a great job of keeping the RH at an acceptable level. It has an internal tank, can be run through the floor as shown and has RH settings. It does have a compressor and fan but noise level is modest. We use it as a supplement to the AC and for storage without. If you have the VFK it will fit under the sink shelve for travel. Could also sit in the tub or on the kitchen counter and drain to gray tank. Will repost in a year or so on long term use. Click image for larger version
2ondago is offline   Reply With Quote
