Old 02-26-2017, 02:53 PM   #21
Is your RV still under warranty? If so you may be able to talk the selling dealer into letting you pay the difference and upgrade the jack to the 4500# Husky. Just a thought.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 02-26-2017, 02:59 PM   #22
http://www.fastecindustrial.com/amkt...STRUCTIONS.pdf
I found some info on your jack. Check out the link above.
DonMcKay is offline   Reply With Quote
Old 02-26-2017, 03:56 PM   #23
Good info there. Shows no fuse but there is a circuit breaker (20A) that appears to be mounted under the upper motor cover.
BIRDS AREN’T REAL
Old 02-27-2017, 07:54 AM   #24
Make sure your battery disconnect switch is on, my Flagstaff requires battery disconnect to be switched to use battery? My light and nearly every thing else works with the disconnect off with shore power but not the jack??
GMC Denali 2500HD 4x4
Columbus 381 FLC 2016
Flagstaff Ultralite 29 RLSS
2013 35 nights, 2014 105 nights, 2015 123 nights, 2016 18 nights 🙁
Mike ONeill is offline   Reply With Quote
Old 02-27-2017, 11:03 AM   #25
Glindz233s's Avatar
Originally Posted by minattz View Post
Thanks for that info. Where did you find the same exact switch. Looking online the manufacture does not sell it separately. Is there a model number or part number i can look up?
RV World of GA near me just because I was in a hurry. I took the switch off first. Sorry but I don't have the switch number but mine is the same jack as yours.
Me, Wifey, Thing 1 & 2 plus Gracie the Shitzu rescue
FR Shamrock 233S 2015
2018 Ram 1500 Hemi 5.7 4x4 3.92
Nights Camped: NOT NEARLY ENOUGH!
Glindz233s is offline   Reply With Quote
Old 02-27-2017, 11:06 AM   #26
Battery disconnect? is this on the jack somewhere? The jack I have does not run directly to the battery. I think you may be thinking of a different model??
minattz is offline   Reply With Quote
Old 03-24-2017, 08:00 PM   #27
mac.dblues's Avatar
Even when i have the 30amp plugged in the hitch will not raise or lower. The light will still come on and off, so that leads me to maybe the motor? I did raise the jack all the way and i since read that will cause the fuse or motor to burn out. I have also read about an inline fuse, BUT i cannot find where that is. I traced the black wire coming from the hitch down and under my tongue, it is covered in the black tubing...but i did not see a little black box that would house the fuse. Does this sound like a fuse issue for only the motor since the light works, or is it the motor itself? It was the first time taking it out so hopefully its nothing too serious. Its parked at my house now, but i need to fix this before my next trip. Thanks guys.
Have you tried manually cranking the jack down some? It could simply be in a bind since you raised it all the way up...
2017 Cherokee Grey Wolf 26RL Dragged around by a 2004 Ford F-150 FX4 5.4L
2018 Nights Camped 05 : 35 total booked
2017 Nights Camped 37
2016 Nights Camped 23 (3 in popup)
Laissez les bons temps rouler!
mac.dblues is offline   Reply With Quote
electric, hitch
