Old 03-09-2016, 06:15 PM   #11
Herk7769's Avatar
Originally Posted by bob caldwell View Post
Herk, why not add a couple jumper wires to battery posts so that the minder would/ will be easy to connect to...
That is the plan. I will be using Powerpole connectors on the battery minder so the connect/disconnect will be fast and easy.
HAM CALLSIGN - KC3FFW
Old 03-09-2016, 10:46 PM   #12
Originally Posted by bikendan View Post
One of the top newbie mistakes is not being aware of all the parasitic power drains in modern RVs.
Installing a battery disconnect switch is a favorite mod and very simple.
a website that should be required reading for all newbies, is "the 12 Volt Side of Life I & II"
Google it.
I'll check it out, thanks!
dstacy969 is offline   Reply With Quote
Old 03-10-2016, 10:32 AM   #13
firsthere's Avatar
My dealer showed us this nice setup that worked great on our 21rb. The large hole was already in place just had to drill two mounting screw locations.
ID:	101532   Click image for larger version
firsthere is offline   Reply With Quote
Old 03-10-2016, 10:41 AM   #14
Originally Posted by Herk7769 View Post
Yep, just was checking out the battery on my Yamaha generator. It is a 12 volt "motorcycle" battery and the generator was put away with it fully charged.
I found it with 3.6 volts so I ordered a new one. Even my 4 stage battery charger couldn't bring it back to life.
I have to disassemble the generator to get to the battery. I also bought a battery minder so it will stay plugged in from now on.
Herk, read this article. It's the most definative on that "fourth" stage thing the're selling. Sure seems like the marketing of a four stage is a hoax to me.
Credit to another forum member for this contribiting article Answer To The Question: Battery Desulfators - Do They Work? - Blog | Impact Battery Blog Just sayin'
Old 03-14-2016, 07:06 PM   #15
updhaul's Avatar
As a new owner you will find a volt-ohm meter will be a great addition to your tool kit. About $20-$30. That way you will be able to check battery voltage at the battery post and so many other problems that can be solved. The battery connections are frequent cause of new "failure" in vehicles and rv's of all types. Check them, make sure trip home didn't loosen up connection enough to cause intermittent problem so you can have confidence it will not reoccur..
updhaul is offline   Reply With Quote
Old 03-14-2016, 08:48 PM   #16
Herk7769's Avatar
I read that article all the way through and it seemed to me the opposite was true. They were only contraindicated in Lithium Batteries because they use a different Chemistry.
"PulseTech to the Rescue!
A few years back Pulse Tech patented a pulse frequency that would dissolve the crystalized sulfate and return it to its original form. And with that the first Battery Desulfator was born! The military was (and is) its primary customer. Their pulse frequency is a range from 22-28 KHz. That is roughly 22,000-28,000 pulses per second. The years of testing has produced empirical data that shows the effect on lead plates and validates their use as a battery desulfator."
Old 04-12-2016, 11:53 PM   #17
Originally Posted by ScottBrownstein View Post
Your converter started supplying 12 volts from the shore power. It will also try to charge the battery, but it sounds like it is incapable of being charged. Leave it hooked to 120 volts for 24 hours. If there is no 12 volt when you disconnect, time for a new battery. Of course check the battery connections first.
The problem seems to be solved. We've camped two weekends since then at campgrounds with electrical hook ups, and after the first weekend being on shore power all weekend, the battery seemed to be fine, and has been since.
Old 04-13-2016, 08:19 AM   #18
Electrical question
Should the battery cut-off switch be turned "off" or "on" when the RV is plugged into shore power and the battery is still in it?
Boomer1968 is offline   Reply With Quote
Old 04-13-2016, 08:23 AM   #19
Flybob's Avatar
ON. The converter charges the battery. The cut off switch is used to disconnect the battery when the unit is not connected to shore power when stored so the parasitic loads do not drain it. Be sure to have the switch on when towing as depending how it was installed, it may disable the break away braking if off.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-13-2016, 05:45 PM   #20
Thanks for the info...... Long time reader but never a poster.
battery, electric, electrical
