Old 04-20-2016, 06:12 AM   #1
kark0202's Avatar
Extra tie downs
Hello. I have a 2013 27bh grey wolf. I am looking for where there are studs on the rear wall of the trailer that i could drill eye bolts into for the purpose of using them to help tie down items on the rear cargo carrier.
kark0202 is offline   Reply With Quote
Old 04-20-2016, 07:13 AM   #2
slide5r4fun's Avatar
I would be reluctant to drill holes in the end wall of my camper to secure cargo. I'm not sure what you're trying to secure on your rack but could you put the eye bolts on the rack itself. We have a cargo rack on the back of our Sabre and I put eye bolts on it to secure bikes to the rack. Here's a pic.
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is offline   Reply With Quote
Old 04-20-2016, 07:24 AM   #3
AquaMan's Avatar
I would have to agree with the above advice, but if you go out in the early morning before the dew has dried off, you can generally see the outline of any structure in the walls. May not give you exact placement, will let you know if there is something there or not.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-20-2016, 07:47 AM   #4
TURBS's Avatar
Yeah I'd suggest rethinking your tie down strategy.
I also have a rear cargo rack and simply use it for cornhole boards and coolers.
I'm able to strap them directly to the rack and be fine.
However if your strapping bikes there should be an arm for the back of the rack that you can strap to.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
