Old 06-10-2018, 10:56 AM   #1
Filling fresh water tank
Im a newbie. Bought a 2018 Grey Wolf 23dbh. Took out for the first time last weekend and filled with water and i assumed it was full because of water coming back out of fill hole and when i set up camp i checked gauge inside and it said i was only a 1/3 full. From what we used for water over the weekend im assuming the gauge was correct. before i take back for service im just wondering if anyone else has run into this issue. I appreciate any feedback. Thank you...
MJ2018 is offline   Reply With Quote
Old 06-10-2018, 11:05 AM   #2
Did you fill it up before you hit the road? If so, the water might have siphoned out while you were driving.
Bruce
Old 06-10-2018, 11:33 AM   #3
no i did not. I filled up at the campground
Old 06-10-2018, 11:58 AM   #4
mz_cummins's Avatar
My 2018 29TE would start back flowing out the fill and only say it had a 1/3, I looked at fill line and they had it ran up and over some other water lines and other things, I re routed it and can fill until it comes out the overflow on the tank
mz_cummins is offline   Reply With Quote
Old 06-10-2018, 12:32 PM   #5
If you try to fill it too fast, it will come back out the fill. I have a 23MK and have to fill it slow until it comes out the overflow/vent under the camper. It takes a while.
jboczek is offline   Reply With Quote
Old 06-10-2018, 12:38 PM   #6
X2
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 06-10-2018, 12:53 PM   #7
Guages are notoriously inaccurate, but tanks can get an air lock and blow back long before they fill. I had a pinched vent line causing the blow back. Is the bottom of your trailer enclosed or open? If open you may be able to see the water level. You may also see the vent line at the top of the tank and verify it is not pinched.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 06-10-2018, 01:06 PM   #8
Check out this thread I started a couple years ago on the issue:
Vent design/location
Old 06-10-2018, 01:30 PM   #9
cavie's Avatar
Your FW tank has an overflow/vent hose. Be sure it is not kinked. On most, it is a hose hanging down next to the tank with no valve on it. Might have a critter in it.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 06-10-2018, 02:22 PM   #10
Tank filling
You could always put a counter on your hose to know for sure how many gallons you’re putting in.
Jeanguypataterubberboot is offline   Reply With Quote
Old 06-10-2018, 03:06 PM   #11
My Rockwood Mini TT will start to spit out the vent line when it is about half full. If I slow the flow for a minute or two then things go back to normal. I suspect it is water left in the vent line from the previous filling that is being pushed out by the force of new water entering the tank. When the vent line has burped then it is being a vent again.
Be careful not to jam a high flow hose down the filler opening. It is possible to create a tight enough connection from the hose fitting and the fill tube to exert a lot of pressure on a full tank and blow the tank up.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
Old 06-10-2018, 03:20 PM   #12
There are two lines hanging down. One is the drain for FW tank and the other one I'm assuming could possibly be the overflow/vent but it has some kind of caulk in it.
Old 06-10-2018, 03:28 PM   #13
Flybob's Avatar
Your sure it is caulk and not a insect larva.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-10-2018, 03:56 PM   #14
i do believe it is just caulk or the same kind of sealant they used to seal underneath the trailer
Old 06-10-2018, 05:31 PM   #15
cavie's Avatar
That is the overflow hose. That's how you know it i is full. Clean it out. See above: Critters. Mud dobbers.
Old 06-10-2018, 05:49 PM   #16
Thank you, I'll clean that out and see what happens when I fill.
Old 06-10-2018, 06:24 PM   #17
BillyBass's Avatar
Thanks guys that good to know. Thats why i like this site
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill ,Alley and Sierra
BillyBass is offline   Reply With Quote
Old 06-10-2018, 06:52 PM   #18
Ran into the same problem a couple weeks ago. Turned out to be mud daubers in the tank vent. Here's how I fixed the problem.
www.forestriverforums.com/forums/f24/wolf-pup-owners-what-is-it-161885.html
Pamlico is offline   Reply With Quote
Old 06-10-2018, 07:02 PM   #19
Even with a clean vent you can still back up if you try to fill too fast. Someone said, and it is true that the tank needs to burp. What I did when we had a gravity fill is I used a inline filter to filter the cg water but it also slowed the flow enough to let the air escape as the water went in. It increases the fill time but when it starts to come out the fill port, you know it is full.
markb422 is offline   Reply With Quote
Old 06-10-2018, 07:13 PM   #20
I had the same problem when I first filled mine. You can buy or I made a filler hose that goes down the filler tube using a garden hose shut off valve and a piece of tubing that fits in the filler tube. I also used a 5 gallon bucket to see how low it took to fill and then used the same setting on the hose to see how long it took to fill the tank half way and full. I have a 70 gallon tank and at half pressure it takes about 15 minutes to fill.
corocky1998 is offline   Reply With Quote
fresh water, tank, water, water tank
