Old 05-17-2018, 11:31 PM   #1
First night in 26DBH, 2 Questikns
Me and my 2 kids took my 2018 26DBH on about a 25 mile trip to the Indiana Dunes/ Lake Michigan.
First question is probably not 26DBH specific, but is there any reason, switch, power button that would prevent the microwave from powering on at all? Was planning to microwave quite a bit of food and tomorrow and itís looking like that wonít be an option as itís dead as could be.
Secondly, I knew I wasnít buying a top notch trailer, but this was the first time I drove it. Was particular to make sure all drawers were closed, etc. One of the large drawers under the dinette swung out and now the front door is all ruined and the stove wonít open. It appears the latch on the drawer is defective. Should I presume the dealership will refuse to fix this damage? Iím not sure how good warranties are on travel trailers. I understand itís getting used and itíll get scratches, etc. but now the entire front door front is cracked and bashed in.
Thanks for any help!
Nbanga01 is offline   Reply With Quote
Old 05-18-2018, 12:04 AM   #2
If it's like the 23dbh there is a switch under the tv mount area that goes back and forth between the fireplace and microwave as it can't run both at the same time.
Not sure about the second issue. Good luck
mijola is offline   Reply With Quote
Old 05-18-2018, 11:20 AM   #3
Switch above the fireplace in the cabinet, flip it to use the microwave. You can either only use the microwave or the fireplace, not both at the same time. Keeps the camper at 30 amps.
decoy562 is offline   Reply With Quote
Old 05-18-2018, 11:29 AM   #4
cavie's Avatar
There should be a plug in the rear of the cabinet to the right of the microwave. or above it. Did you try to reset the circuit breaker? Also, the switch at the fireplace as stated above. I more would be the GFI if it is in the bathroom. They're not supposed to put the GFI on Microwaves but it has been done.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Newley Retired.
cavie is online now   Reply With Quote
Old 05-18-2018, 11:36 AM   #5
fonzie's Avatar
I have to ask: you were hook up to shore power? for the micro-wave to work.
Fonzie
Old 05-18-2018, 11:44 AM   #6
Fulltime family RVer
For the second, they absolutely should warrant that. If they don't, go to the manufacturer.
ependydad is online now   Reply With Quote
Old 05-18-2018, 01:23 PM   #7
Pockets
The other issue that it could be is that the GFCI fuse may be tripped. Check out the fuse box and look for a fuse that is in the middle position. If there is, switch to off to reset it and then flip it on.
Or could be the switch that others above have been mentioning. I don't have a fireplace, just a menopausal wife to keep me warm.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg
2015(36 nights) 2016(74 nights) 2017(174) 2018(105 nights)
Pockets is offline   Reply With Quote
Old 05-18-2018, 02:49 PM   #8
Thatís what it was! Thanks so much. I wish they wouldíve shown me that at delivery haha.
Old 05-19-2018, 12:37 PM   #9
Mch5jdm's Avatar
Where?Click image for larger version
ID:	172458 is the switch? Looked all over my 23DBH.
Letís go camping!
Mch5jdm is offline   Reply With Quote
Old Yesterday, 08:24 PM   #10
Originally Posted by Mch5jdm View Post
Where?Attachment 172458 is the switch? Looked all over my 23DBH.
Mine is right where your DVD of oc3ans eleven is
26dbh
