Old 04-25-2017, 08:03 PM   #1
First weekend out
So we had our first weekend out and went to Luray Caverns in Luray, VA on Saturday. On Sunday we went to Shenandoah Caverns. I recommend Shenandoah. Smaller, fewer people, family owned, great caverns, and in better shape.
Also stayed at Jellystone. It was fantastic.
Our RAM power jack died though. Doesn't have any power at all. Recommendations?
https://lh3.googleusercontent.com/aY...=w1265-h949-no
xivjae is offline   Reply With Quote
Old 04-25-2017, 08:07 PM   #2
fonzie's Avatar
Usually there is an in-line fuse (30 amps) have you check if burnt?
Fonzie
Old 04-25-2017, 08:10 PM   #3
K2Kevin's Avatar
Sounds like a fuse, which reminds me to stock up on a few.
K2Kevin is offline   Reply With Quote
Old 04-25-2017, 08:12 PM   #4
Fuse still looks good
Old 04-25-2017, 08:18 PM   #5
B and B's Avatar
While holding the switch to go down wrap the motor hard, might be as simple as brush seating inside the motor.
Old 04-25-2017, 08:21 PM   #6
Check the circuit breaker under the front of the camper on the frame.
2017 F350 SRW Gasser
2016 Keystone Passport 3350BH
MarcS is offline   Reply With Quote
Old 04-25-2017, 08:31 PM   #7
Is there a way to reset it, or do I have to replace that one?
It's in storage right now and I want to be prepared when I go out. I am fairly certain that I know where the circuit breaker is.
Thanks everyone!
Old 04-25-2017, 08:33 PM   #8
K2Kevin's Avatar
I'm not 100% but expect it to be an automotive fuse, so bring a fuse kit (includes a bunch of sizes). 15 - 30 amp should cover you for anything. Mine has both auto and mini fuses.
Old 04-26-2017, 04:54 AM   #9
Thanks everyone!
If the circuit breaker popped, you can reset it!
Old 04-26-2017, 10:04 AM   #10
K2Kevin's Avatar
A lot of power tongue jacks have an inline fuse. Maybe follow the power wire, you may find one.
Old 04-26-2017, 10:42 AM   #11
May also want to check the ground to the power jack, if the fuse is not your problem
dlinville is offline   Reply With Quote
Old 04-26-2017, 04:46 PM   #12
Got out there and ran a few tests, found some new stuff and figured out it was the fuse. Now, where does one find a 30a 500v 6x30 ceramic fuse?
Old 04-26-2017, 04:58 PM   #13
fonzie's Avatar
just go to your auto parts store
Fonzie
Old 04-26-2017, 05:00 PM   #14
I've been to three. No luck on that size fuse.
Old 04-26-2017, 05:00 PM   #15
I'll keep checking online.
Old 04-26-2017, 05:09 PM   #16
fonzie's Avatar
Here this will do the job, does not have to be 500 volts
https://www.amazon.com/6x30mm-Fuses-...6+x+30+mm+fuse
Fonzie
Old 04-26-2017, 09:10 PM   #17
K2Kevin's Avatar
Home Depot, lowes, menards all should have a 30amp ceramic. Where's radio shack when you need them.
Old 04-26-2017, 09:14 PM   #18
I guess we live in some other world. None of the car parts stores, Lowe's, Home Depot, or radio shack had them. I just ordered from Amazon and will roll with that. Thanks everyone!
Old 04-26-2017, 09:57 PM   #19
jtstromsburg's Avatar
If it were me, I'd grab a regular 30a tube fuse and use that till the other(s) come from amazon. As long as it's a quick trip fuse, should work. I've had to do similar to keep equipment running at the school I do maintenance for.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
