08-16-2017, 08:44 AM
freezer icing up
Anyone else have a problem with the fridge freezer icing up? Had to defrost mine every week...it's the 3.3 in a Wolf Pup..
08-16-2017, 08:45 AM
Perhaps you have a door seal leaking?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
08-16-2017, 08:47 AM
Did the pulling a dollar around the seal..seems tight..
08-16-2017, 08:56 AM
I would expect your unit to be a sealed system. Unlike charged systems that will freeze when refrigerant is low. My WAG is still on warm air getting into your unit.
Can you turn it off, defrost it, dry it and turn it back on for the required amount of time without opening it to test? Just shooting in the dark here...
Bob & Michelle
08-16-2017, 09:04 AM
Will try that when I get back to home base..thanks
08-16-2017, 09:11 AM
My new Flagstaff is having the same issue with nothing in the freezer. Seal is leaking and ice is building up in one place where the air leaks in.
On a previous trailer I solved the problem by adding a piece of card stock behind the seal on he door so more pressure would be placed on the seal at that area. If that doesn't work I'll take it to the dealer and wait while they get around to fixing it.
08-16-2017, 09:15 AM
Was trying to avoid the dealer thing..the fins on the back wall ice up and then the freezer compartment really ices/ frost up...lower fridge area stays 40 or less..I have a frigemate fan in the bottom..maybe do away with the fan?
08-16-2017, 09:20 AM
How much ice/frost?
Not uncommon for ours to develop ice on some of the fins and a bit of frost on the freezer sides in a week. Normal on a non frost-free refrigerator.
08-16-2017, 09:23 AM
Fins are almost completely covered and top of freezer about 1-2" of frost/ice..
08-16-2017, 09:29 AM
What are the outdoor temps you are seeing? Just curious...
Bob & Michelle
08-16-2017, 09:37 AM
With that amount of ice you are either dehydrating the food in the freezer because it's not properly wrapped/sealed ; you are opening the door too often and letting in humid air; you have a door seal leak.
If the door is leaking you will typically have a small area where frost is extending up to where the door seal begins.
In humid climates it's best to open the door only when necessary and no more than needed.
When the door is closed and properly sealed some frost will form as the humidity in the air is frozen. Once that happens it's going to take some more moisture entering the freezer to form more frost/ice. Only three possibilities. Frequent door opening, Food not wrapped/packaged/sealed properly, and door seal leakage.
70-80° here..high 90s at home..doesn't seem to make that much of a difference..have also tried different temp settings on the panel..
08-16-2017, 07:19 PM
Geesh... if you are getting 1-2" of frost/ice buildup in a WEEK you must be living under water. That's a tremendous amount of moisture.
Seriously, if your seals are good, I don't know what to suggest??
08-16-2017, 07:25 PM
Probably not sealed.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
08-16-2017, 07:44 PM
Working or not working, that much ice means somehow there is a lot of moisture getting into the freezer. You said you checked the door so the only other possibility is it is opened too often in high humidity.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-17-2017, 01:45 PM
I find a little fridge fan helps with this issue a LOT. The fan not only circulates the cool air, but helps with moisture production from opening door or contents of fridge.
I still get frost build up on the thermistor side on the fins after 3-4 days, this is pretty normal IMO. I do try to wipe off condensation on bottles and other items before placing in fridge. I also wipe off any interior condensation.
Also try turning the fridge temp down. Some have had issues when keeping the fridge temp on the highest setting. If I leave my Norcold on highest setting for more then 2 days, its so cold it freeze contents of fridge as well. I start at 3 and turn it down to 1 after about 24 hours.
