Old 09-18-2011, 07:43 PM   #1
NorminN.B.'s Avatar
Furnace control
I tried my furnace, the other day. The inside temp was 60 degrees. The furnace started as soon as I moved the thermostat up to 10 degrees. The furnace ran good, but when the temp hit 70, where the stat was set, it didn't shut off. The temp was nearing 80 degrees, and I shut it down. Would the thermostat be bad, or sticking? I took the cover off, in case there was some dust on a bug in there, but didn't find anything. The trailer is an 09 Cherokee, 39L. Thanks
NorminN.B. is offline   Reply With Quote
Old 09-18-2011, 09:26 PM   #2
Herk7769's Avatar
Sounds like a bad thermostat. It controls the furnace.
Don't confuse the fan with the fire though. The fan will run for a few minutes after the thermostat tells the fire to shut off to cool the heat box. It also starts the fan first; prior to starting the fire; A "sail switch" in the furnace outflow has to close before the fire is allowed to start.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 09-19-2011, 10:33 AM   #3
NorminN.B.'s Avatar
Thanks, Herk. Thats what I thought, also. Will have to look for a new thermostat.
