Old 10-30-2015, 07:11 PM   #1
Furnace help!!! Cherokee 27rk
We bought this great unit used. It's a 2015 model. We just started to use the furnace tonight. Air seems to be blowing from the furnace but not through the floor vents.
Does anyone know if this is correct or how to get the warm air to blow through the floor vents.
I have attached a pic. The warm air is blowing from this area below the oven. Click image for larger version
Name:	ImageUploadedByForest River Forums1446250263.884721.jpg
Bnanewbie is offline   Reply With Quote
Old 10-30-2015, 07:52 PM   #2
fonzie's Avatar
It sounds like your front metal cover of the furnace is not in place and air is coming through the front panel. I would remove front wood grill and see if furnace metal cover is in place. In my unit I don't have air coming from front grill, that is the air intake (return) to furnace.....
ID:	93331   Click image for larger version
Fonzie
Old 10-30-2015, 07:53 PM   #3
VinceU's Avatar
I have attached a pic. The warm air is blowing from this area below the oven. Attachment 93330
The grate you show is the cold air return. One or more of the aluminum hoses connected to the heater has fallen off or was never connected. This
Hils w certainly
Old 10-30-2015, 08:47 PM   #4
Okay. I tried to take the grill off and there are either special screws or they are stripped. Oh Lordy it's gonna be cold tonight lol. Would it hurt it to run it like this? It warmed things up for a bit when I had it on but I'm not sure what (if any) damage it would do
Old 10-30-2015, 09:12 PM   #5
Bluepill's Avatar
I would not want to run a GAS HEATER with any defects. Do you have 120 volt AC power available? If so, run your heat pump (if equipped) or a portable electric heater.
SAFETY FIRST
2008 Itasca Meridian 37H
Old 10-30-2015, 09:50 PM   #6
Okay. Thank you. Bundling up then trying to find a screwdriver or not to work tomorrow.
Thanks again!!!
Old 10-31-2015, 12:02 PM   #7
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Bnanewbie.....make absolutely sure you have a carbon monoxide monitor in your RV.....no debate about how serious that can be. And I'm not talking about a smoke detector either. Although Smoke Detectors are critical also. Bluepill is absolutely right about what he said. You could wake up dead if things aren't working right. Don't take ANY chances at all. I was in the heating and AC business for 40 years, so I know what I'm talking about.
Grampa Jim is offline   Reply With Quote
Old 10-31-2015, 12:18 PM   #8
ngg
I had the same problem wih my Flagstaff 5th wheel. No air from the vents in the coach and warm air blowing through the grate bleow the oven. Had never really used the furnace until the Yukon trip this past Aug & Sept. When i took the grate off i learned that there was a knockout in the bottom of the furnace and the ducts were hooked up to it. The problem was that there was also a knock out on the top of the furncace ("6 inches x 12")that had been "knocked out" by someone & the air was blowing out the top of the furmace. Path of least resistance. As a temporary fix i had a 1/4 " steel plate cut and set it on top of the furnace to cover the hole. Air imediately started flowing through the ducts.
It was out of warranty but when i sent pictures to Forest River they replaced the furnace since it had obviously left the factory with this hole.
ngg is offline   Reply With Quote
Old 10-31-2015, 12:32 PM   #9
A32Deuce's Avatar
The bits for the screws that hold the front grill on take a small square bit. Looks like a phillips stripped out when you try one.
A32Deuce is online now   Reply With Quote
Old 10-31-2015, 02:53 PM   #10
I appreciate the feedback m. I did not have it on last night. I was able to get the grill off a few minutes ago and this is what we find. Should this metal box have been sealed??Click image for larger version
Name:	ImageUploadedByForest River Forums1446321180.980641.jpg
cherokee, furnace
