Old 06-16-2016, 11:18 PM   #1
Fuse Panel Fan
2nd night of our camping trip and the fan for the fuse panel starts and stops every 15-20 seconds and runs for 3-5 seconds. Never had this happen and not sure what the problem is.
2015 274DB
Astpman is offline   Reply With Quote
Old 06-16-2016, 11:20 PM   #2
Left Coast
It's your converter cooling fan......your probably using lots of power..
Old 06-16-2016, 11:20 PM   #3
dea49's Avatar
Could there be a build up of dust on the power supply or using more 12v than the night before?
dea49 is offline   Reply With Quote
Old 06-16-2016, 11:33 PM   #4
It's weird cause it's night now and no AC is on and just one light on in bathroom (we use as night light). I would think if it needs to cool the converter the fan would run for a couple minutes straight. It's just runs for 3 seconds, turns off for 15-20 seconds and cycles again continuously.
Old 06-25-2016, 07:35 PM   #5
kc5mhb's Avatar
Depends upon the amount of load on the inverter. The fan adjusts depending on how many lights I have on. I'm looking to go with LED bulbs throughout the trailer and that should cut back on how much the fan runs.
2019 Flagstaff V-Lite 30WTBSV
2000 F250 CC SD V10 4X4 8' bed, 4:30 gears, SCT X3
2007 Mustang Convertible V6 - Lots of GT mods
1965 Mustang Coupe I6, 3 spd. manual
1963 Thunderbird Landau 390
kc5mhb is offline   Reply With Quote
Old 06-27-2016, 01:45 PM   #6
Head Rambler
Sounds like either the fan itself is going bad or the converter is failing.
What happens if you turn on several lights at the same time? Does it stay on then? Provided you have Incandescent lamps and not LED's.
Gotta go campin!
fan, fuse
