Old 09-07-2018, 04:38 PM   #1
Gap under bed in front.
Just bought a 2017 16 bhs and got under the bed and noticed a gap between the floor and the front wall that I can stick my fingers into down to my knuckles until I hit the black nylon that lines the underneath of the camper. Anybody else have this or is it just mine?
Peprice is offline   Reply With Quote
Old 09-07-2018, 07:56 PM   #2
Fixed it
Put 1 inch square soft foam in the crevice then put a 1x3 on top of it.
Old 09-08-2018, 11:09 AM   #3
Wolf pup 16fq
Mine has that same gap. Worry about winter mice chewing thru the black sheeting and coming in. How and where did you attach the 1 x 3?
Hat creek is offline   Reply With Quote
Old 09-08-2018, 05:39 PM   #4
Here is the gap I was speaking off, if it will let me post this pic Iíll post a pic of the fix.
Old 09-08-2018, 05:59 PM   #5
Pic of the fix
Hopefully this pic goes through.
Old 09-09-2018, 02:14 PM   #6
K2Kevin's Avatar
Thatís a big gap and a nice fix. I have a 2017.5 16BHS and have just the rounded corner 1/8 gap in the front there. Cannot see past the flooring at all. I did recently fill that area with clear flexible silicon.
I had ants under the water heater, so filled silicon where ever I could find possible entrances (the propane line went through a hole I could see light through). Filled that hole (from the top and underneath) as well as that crevasse in the front floor storage area.
K2Kevin is offline   Reply With Quote
Old 09-09-2018, 02:25 PM   #7
Shameful, just more quality workmanship.
Decon Blue is offline   Reply With Quote
Old 09-09-2018, 03:18 PM   #8
Question for you, how far forward does your floor go? Does it go all the way underneath the wall or does it stop before it. I am wondering just due to structural support of the floor going under the wall. This is what I am concerned about.
Old 09-09-2018, 03:23 PM   #9
K2Kevin's Avatar
It goes all the way to the front wall but doesnít seem to be attached. May offer a bit of support for the front, but probably not enough to notice. Looks like a defect in your case and most likely your fix is better then what FR would do.
Old 09-09-2018, 03:29 PM   #10
I emailed forest river today about it and will call them to see what they say. And you are probably right on my fix is better. Thanks for the info about how yours is, really appreciate it.
Old 09-09-2018, 03:35 PM   #11
K2Kevin's Avatar
I did add photos above
Old 09-09-2018, 05:47 PM   #12
My 26rr and 27rr both had this. I filled it with silicon. I like the 1x3 idea and will add that.
n0ms is offline   Reply With Quote
bed
