03-13-2016, 06:09 PM
Newbie
Generator
I have a new 2016 Grey Wolf 23DBH, will a Troy Built 5000watt generator run my A/C and a couple of lights? I was going to try it but thought I'd ask first. Thanks
03-13-2016, 06:15 PM
03-13-2016, 06:26 PM
You will most likely not be able to use it in a campground due to noise. It is a fine construction generator, but not designed for RV use.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-13-2016, 07:31 PM
Oh My! PLEASE don't do that to your fellow campers.
Unless your at a NASCAR race or boondocking with no one nearby.
That generator will exceed every campgrounds noise level rules.
03-13-2016, 07:57 PM
Newbie
Haha, no I'm not thinking of using it in a CG, I'm thinking boondocking or during a power outage due to a storm since I live on the gulfcoast.
03-13-2016, 08:13 PM
Who Dares, Wins
I run my whole house on a 5500 watt geni... You'll be fine.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
03-13-2016, 10:13 PM
Then go for it.
You also should check out the Champion line of generators.
Great customer support and generally quieter than other similarly priced open frame generators.
04-02-2016, 01:32 PM
Hello...we are new to the rv world...but happy to be starting out. We have a Forest River RK and are looking for a good generator that we can use in campgrounds and not disturb anyone. We would like to be able to power everything in the trailer...especially the a/c. Any suggestions?
04-02-2016, 01:46 PM
Here is a link to a product review I did for the Yamaha EF2000isV2 inverter generators I bought. Very popular model\solution.
http://www.forestriverforums.com/for...it-100585.html
2016 Jayco Eagle 330RSTS = " Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = " Hagrid"
360 degree Virtual Tour
04-02-2016, 02:07 PM
You need to post the brand and model number, not just RK.
Also which a/c does it have 13.5k or 15k? Are there 1 or 2 a/c's?
Then there's getting one bigger and heavier 3000+w one or getting a pair of smaller and lighter 2000w units to parallel them.
Minimum would be a Yamaha 2400, which runs most 13.5 a/c's.
The newest one on the market, which will turn RV'ers heads, is the new Champion 3500w with remote start.
Pay attention to db ratings.
04-29-2016, 02:24 PM
Newbie
Ok, I have a Troy built 5000watt....6250 starting watts generator.
Using the 25ft cord from trailer and an additional 25ft 30amp ext to a 30 amp adapter for the 4 prong generator plug.
My a/c is 13.5amp.
Keeps tripping the breaker on the generator after a couple of minutes with a/c on and only the refrigerator on inside the TT.
The generator is 7 years old and runs great.
Any suggestions on why it trips the breaker?
04-29-2016, 03:04 PM
Newbie
Update on post above.
Changed the 30amp adapter out for the 15M / 30F adapter and it works fine.
Used the same adapter on my Honda 2000watt/ 3000starting watt gen and it worked fine also!?
So why wont it work with the 30amp 4 prong adapter?
