Old 03-17-2017, 09:37 PM   #1
smnavalley's Avatar
Generator large enough for A/C in 2017 26DBH
Hello out there...! I'm looking for a generator large enough to run the air conditioning in our 2017 26DBH. Our current generator isn't large enough. What is everyone using for their Grey Wolf?
2013 Ford F-150 5.0 Super Crew 4x4
2017 Grey Wolf 26DBH
smnavalley is offline   Reply With Quote
Old 03-17-2017, 09:45 PM   #2
bikendan's Avatar
Is it a 13.5k or 15k a/c?
Makes a difference.
Equalizer WDH
Old 03-17-2017, 09:47 PM   #3
smnavalley's Avatar
My apologies. It's a 15k
Old 03-17-2017, 11:49 PM   #4
bikendan's Avatar
Then you'll need at least a 3000w INVERTER generator.
Or a pair of paralleled 2000w INVERTER generators.
Equalizer WDH
Old 03-18-2017, 12:26 PM   #5
I have a new 2017 Catalina 283 with 15 K A/C, and, and I have just learned that my Honda 3000 Invertor can run the A/C fine with lights and TV on. But if my uses the hair dryer, it boggs down. Hope this will help.
Slow but Steady is offline   Reply With Quote
Old 03-18-2017, 12:51 PM   #6
smnavalley's Avatar
Thank you!
Old 03-18-2017, 12:52 PM   #7
smnavalley's Avatar
It does, thank you!
Old 03-18-2017, 01:07 PM   #8
Big enough generator
I just got a Champion 2000w inverter gen yesterday, Tried it out, ran everything but 13.5k A/C. Ironically, yesterday my electrical service here at t he cg fried itself due to loose connections. So up jumps the new generator! Put in oil, gas, fired it up at 2:30 pm, and turned it off at 10pm. Started it back up at 8:15am and it ran for another hour before running out of gas. 8 1/2 hours running on a little less than 1 gallon, and ran our residential fridge and every thing else, I did turn off the electric w/h because it wasn't needed. It did great! Amazon delivered in 2 days for $472.00 Couldn't be happier! Have ordered the parallel hook up in anticipation of getting a second one. That will give me 3000watts of power.
Check these out. Not a Honda, but 2 plus the parallel kit for the price of one 2000w Honda.
Sorry to go on and on, but I'm just so impressed.
Robert
pelican is offline   Reply With Quote
Old 03-18-2017, 04:06 PM   #9
DavidBo's Avatar
Robert
I've got the 3000W version and so far so good. The Honda's have set the bar quality-wise, but that comes at a price. Yamaha is also a good choice, but bang for the buck, I'm pretty happy with my Champion. It even runs my 13.5k A/C in econo mode, but nothing else, of course.
DavidBo is offline   Reply With Quote
Old 03-18-2017, 04:29 PM   #10
smnavalley's Avatar
How loud is the Champion, compared to the Honda?
Old 03-18-2017, 04:38 PM   #11
I have a 26RR with a 15k AC and run it with a Honda EM5000SX. I can run the AC, the microwave, and everything else with no bogging. The only issue is on really hot days when microwaving with the AC on and the electric water heater kicks on.....then it will pop a breaker on the generator.
2016 26RR and a 2018 OR371MBH
mxdad is offline   Reply With Quote
Old 03-18-2017, 05:31 PM   #12
HONDAMAN174's Avatar
I would say the champions are a pretty good value and there are several flavors available- 2000, 2800, 3100, 3400, 3500 and some with remote start. Loudness is a little bit more than the hondas but nothing to start a lynch mob at a campground. Unless it is an open frame!
Just glad to get away
Old 03-19-2017, 05:45 AM   #13
DouglasReid's Avatar
I give up, what is an Inverter generator? I have two generators, a whole house Onan and a portable generic. Both produce AC current.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-19-2017, 10:02 AM   #14
DavidBo's Avatar
Most generators are the open framed contractor style. They use an alternator creating AC directly and the voltage is controlled with engine RPM. The disadvantage there is noise due to the open frame, and inefficiency because the engine has to run at a certain RPM regardless of load. The current is also "dirty" and not well suite to sensitive electronics.
Inverter gennys make DC power initially, then converts it to AC electronically through an inverter. This creates nice, clean electricity and fuel consumption is reduced because the engine can be throttled back under light loads. The econo-mode combined with the enclosed case means much less noise. Show up at a campground with a contractor unit and get ready to be real unpopular.
Old 03-19-2017, 10:06 AM   #15
DavidBo's Avatar
I don't have a Honda for a direct comparison, but according to other reviews and a few YouTube videos the Champ is slightly louder DB wise, but not by much as previously mentioned.
Old 03-19-2017, 11:34 AM   #16
Generator
The champion 2000w inverter gen weighs 48.5 pounds, and is rated @53db.
Old 03-19-2017, 12:00 PM   #17
bikendan's Avatar
biggest difference is Inverter generators are MUCH quieter than open frame contractor style generators.
Equalizer WDH
Old 03-19-2017, 09:14 PM   #18
I got a 2016 26DBH I use a Champion 3000 RV gen. Does all I need
hotheadbilly is offline   Reply With Quote
Old 03-20-2017, 11:03 AM   #19
smnavalley's Avatar
13.5k or 15k A/C?
Old 03-20-2017, 11:28 AM   #20
13.5k or 15k A/C?
It will handle either one! Youroo!!
generator
