Old 05-05-2015, 08:07 PM   #1
Got Mice?
I have been battling mice getting into the trailer during storage. I use sticky traps and works great, but just when u thought you got them all, their back. Tried irish spring soap, herb mixture, copper brillo pads..
Any thing that works? Or Any ideas where they are getting in at?
Thank you
M4hughes is offline   Reply With Quote
Old 05-05-2015, 08:22 PM   #2
Go Pack Go!!
codespy's Avatar
The MFR's usually do a poor job on brand new RV's sealing up the penetrations on the underbelly. Since I started crawling under our RV's every two years armed with a can or two of Great Stuff, we have not had another instance of mice in our campers. I also go inside the camper at the same penetrations and spray down, just to really make it hard for them to get in.
On our one camper, I had to shoot the whole perimeter of the top of the black water tank to achieve a mouse-less camper.
They may start to chew to re-open the opening, but that's where persistent maintenance pays off. My wife hates small turds in our camper!
codespy is offline   Reply With Quote
Old 05-05-2015, 08:26 PM   #3
Thanks,
I was also assuming the holding tanks. Thought i sealed them up well on the interior with Great Stuff.
What was the easiest way on the underside?
Old 05-05-2015, 08:46 PM   #4
Go Pack Go!!
codespy's Avatar
Same Great Stuff, but I had to use 2 1/2 straws just to get the right angle on the can to spray the foam out of the can.
I also learned quickly to tape the straws together. The first time I tried it, the straws separated and I wound up with more foam on my clothes than in the desired spots on the camper. That stuff can get kind of nasty on your clothes and/or skin.
Even in areas where they used black tape on the underbelly around the penetrations, you have to coat it good with the foam to leave no openings. It's amazing how small of a hole those little furry things can get through.
Old 05-05-2015, 08:46 PM   #5
Flagstaffer06's Avatar
I did the same thing with Great Stuff foam and it worked awesome. From what I have read, a hole the size of a pencil eraser those buggers can find their way in.
We have sealed up ours well and this year added dryer sheets all over the place throughout the camper and we had nothing atleast that I know of....
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 05-05-2015, 08:46 PM   #6
Flybob's Avatar
get 2-3 old mugs or glasses. Put 2-3 cotton balls in each one. Now put 5-6 drops of essential oil of peppermint on the cotton balls. You need to use essential oil ( homeopathic shop) it will not work with food grade peppermint oil. Not only does it make the RV smell good, but mice hate it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-05-2015, 08:54 PM   #7
Go Pack Go!!
codespy's Avatar
That's a good suggestion as opposed to moth balls that some people use.
I also take our small plastic garbage can in the camper (about 24" high) and fill it up about 1/4 with water when we close it up for the winter. I set it near a couch but not right up against it. Mice seem to like water once in a while. If there happens to be one that gets into my camper (has not happened for 5 years now), they eventually get into the garbage can but cannot get out because its too slippery, and they can't get good leverage to jump. They eventually perish by drowning.
Old 05-05-2015, 09:26 PM   #8
Taranwanderer's Avatar
While the "sealing up the points of entry" approach is always a great start, they are enterprising little b@$tard$ and a good second line of defense is the Rat Zapper:
Amazon.com : Rat Zapper Classic RZC001 : Home Pest Control Traps : Patio, Lawn & Garden
It works on mice as well as rats, I bagged two of them this past winter in my Wrangler TJ that lives outside. Interestingly enough, I had it inside the XLR for several months without catching a thing, so I was starting to think that it didn't work. But then I put it in the Jeep and had two within a matter of days. So I guess the XLR guys did a pretty good job of sealing my underside! At any rate, the Rat Zapper works, it uses batteries, is reusable, and doesn't have springs to snap back and catch your fingers.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 05-05-2015, 09:48 PM   #9
GreenImp's Avatar
Send a message via MSN to GreenImp
I successfully used a similar trap recently. A 5g bucket with wire, pop can, peanut butter, and wooden ramp. Water, anti freeze, or simply nothing all work well (I used water). This would work well for long term storage as it can trap many times over without need for reset.
Bucket Mouse Traps |
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 05-06-2015, 01:31 PM   #10
cdangel0's Avatar
I guess I'm old fashioned. I just get a little used kitty litter and toss it under the camper. There's not enough of it for a human to smell but the mice can certainly sense there's a predator around and stay away.
Granted - I only worry about mice in the camper over the winter when I'm not using it.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
