Old 03-20-2018, 05:08 PM   #1
Gray Tank Leak
Hey guys, I have a small leak coming from the gray tank where it meets the ABS pipe that drain the tanks and has a adjustable clamp. I need to re-seal the pipe there and it seems to be white in color. Does any one knows what type or brand of sealant is needed for this repair?
leonards is offline   Reply With Quote
Old 03-20-2018, 05:36 PM   #2
Picture? I would think if it has a hose clamp that sealant would not be necessary? I would just want to make sure it was safe with drinking water once dried? Silicone?
Kimber45 is offline   Reply With Quote
Old 03-20-2018, 05:58 PM   #3
Flybob's Avatar
This is the gray tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-20-2018, 05:59 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I agree, a picture would help.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 03-20-2018, 07:18 PM   #5
Sorry I thought I read fresh water tank and was thinking the drain line for that. Ive never been under a unit to see how that hard plastic for the grey/black tanks actually attaches to the tank.
Old 03-20-2018, 08:47 PM   #6
Trailer is in storage and will need to take picture tomorrow
Old 03-24-2018, 08:39 PM   #7
Sorry for the delay, here are two pictures of what it looks like. Click image for larger version
ID:	166089Click image for larger version
Old 03-24-2018, 08:46 PM   #8
Flybob's Avatar
What year is this trailer?
TST Tire Monitors
2 100W solar panels
Old 03-24-2018, 08:47 PM   #9
2016 Gray Wolf 26bdh
Old 03-27-2018, 02:29 PM   #10
That is the same leak mine had. That is a screw up from factory. I just bought a 3 1/2" (I think) rubber coupler hose and clamped one end to the tank and the other to the fitting. I removed the whole fitting assembly at the gate valve and fitted it up to the tank. Sorry, I don't have any pics right now. Mine is still under warranty but didn't want to mess with the dealership to fix it. They kept it forever last time and it took them 4 times/trips and still couldn't fix it.
2017 Grey Wolf 23DBH towed with
2005 GMC Sierra 2500HD Duramax
gmmastertech1 is offline   Reply With Quote
Old 03-27-2018, 03:59 PM   #11
Just to be clear you connected the rubber coupler to the outside of the tanks connection? Hows it holding up?
Old 03-29-2018, 12:32 PM   #12
Hate to be a bother but any thoughts and/or suggestions on this matter? Have a week long trip starting this weekend and would like to get it fixed. Dealer is not an option because of delay and simple repair. Thanks in advance
Old 03-29-2018, 01:21 PM   #13
I believe that is what he is saying.
I take it as remove that whole section from the tank forward (to the valve).
The pipe and tank outlet appear to be the same diameter. I would cut the plastic coupler out (that is on there now) and get a rubber coupler, attach one end to the tank outlet and the other straight to the pipe.
You can measure to make sure they are the same diameter. If so you wont have a problem. If they are different look for a coupler that has different sizes on opposite ends to meet your needs.
Seems like a simple fix and should hold up, maybe get it addressed further from the dealer after your trip.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 03-29-2018, 01:34 PM   #14
I see, thank you..
Old 04-03-2018, 02:33 PM   #15
Sorry about the delay! Yes, outside to outside. It is under no pressure and is the same setup used in some home plumbing drain/septic lines. It has been a year and absolutely no leaks. It was a terrible glue job from the factory.
Old 04-03-2018, 04:56 PM   #16
Contacted FR service department and it turns out that they use butyl tape in the joints.
Old 04-04-2018, 11:15 AM   #17
Interesting. Mine was definitely glued. I have a video on Google photos of it leaking but can't get it to load.
Old 04-09-2018, 02:37 PM   #18
K2Kevin's Avatar
Im no plumber, but since its not under any real pressure, it would seem a very simply fix.
I would think you can remove the hose clamp, put the pipe out a bit (If its not actually glued), add a nice layer of outdoor pipe sealant and crank that hose clamp down again.
K2Kevin is offline   Reply With Quote
leak, tank
