Old 08-19-2013, 05:04 PM   #1
camperguy172's Avatar
Gray wolf bh26
We just came home from a weekend with our new camper. It worked great. Just wondering if there was a way to tie awning down while its out? Any tips
camperguy172 is offline   Reply With Quote
Old 08-19-2013, 08:24 PM   #2
PHS79's Avatar
I am assuming that you have a Dometic power awning. If so you must use a pole of some sort to support the awning and then straps & anchors. Here is my 26BH with a pole kit that I bought from a member here that was manufacturing them, but he has stopped making the kits. There are a couple more pictures in one of my albums from when I was installing them.
Here is another setup that a member made.
Awning poles
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 08-19-2013, 08:41 PM   #3
Thank you. That looks like a great idea. Mine is a manual one. We just got back from pymatuning in Jamestown pa.
Old 08-19-2013, 08:52 PM   #4
PHS79's Avatar
Since you have the manual awning, all you need is 2 ratchet straps and 2 screw in dog anchors. Connect the strap to the awning tube, or the end of the arms that the awning tube connects to. Screw in the dog anchors either directly below the awning or slightly out (away the camper), then connect the strap to the anchors. Ratchet the straps until they have slight pressure on them.
Or they do make kits that you can buy, but making your own is cheaper.
Hope that helps!
nights camped:
Old 08-19-2013, 08:55 PM   #5
TURBS's Avatar
Hope that helps!
To further add to your post you should be able to take the lower arms off of camper via the quick release and use them as stabilizers.
Old 08-19-2013, 09:00 PM   #6
TURBS's Avatar
Remove arm here
Should look like this when done.
Old 08-19-2013, 09:03 PM   #7
I don't have quick release. But I'll try the tie downs. Thank you
Old 08-19-2013, 09:04 PM   #8
TURBS's Avatar
Carefree awning?
Old 08-19-2013, 09:14 PM   #9
I think that is what it is. It has a arm with a shock that you pull up or down in the middle to adjust your pitch
Old 08-19-2013, 09:16 PM   #10
TURBS's Avatar
I'd be curious to see a pic of it sometime.
Turbs
