Old 08-13-2013, 10:56 AM   #1
Grey Wolf 26DBH
We bought our 26dbh(13) in March, and have been on several trips with no issues. However after having sat for the last 3 weeks we've noticed there is a "silk fence" like under belly at the rear of the trailer where the tub and toilet sit that is collecting water. There hasn't been any water in the tanks since We left the campground dump station 175 miles away! Any ideas??
schusters07 is offline   Reply With Quote
Old 08-18-2013, 09:27 AM   #2
BandJCarm's Avatar
I have same model.
Do you mean water inside or underneath? Not sure what "silk fence" means.
BandJCarm is online now   Reply With Quote
Old 08-18-2013, 10:24 AM   #3
It's underneath the trailer on the outside but directly under where the tubs is. Silk fence in the only thing I can think of to describe the material attached to the under part of the trailer
Old 08-18-2013, 10:29 AM   #4
BandJCarm's Avatar
OH, ok.
I know when I got mine home from dealer, there was water leaking under trailer. The Tech, in his walkthrough, had added SOME water to the fresh water tank to demonstrate its use. Bad thing with this model, you have to crawl under trailer to almost MIDDLE of it, and unscrew a valvecock to drain the fresh water tank. He had tried to tighten it, and did not tighten it all the way, so it drained a little. I opened it, got a a face full, and it drained totally. The fresh water tank showed empty on the gauge, but it wasn't.
If you have not done that, you probably have water in the fresh water tank.
Old 08-18-2013, 10:32 AM   #5
I will pass it on to the husband! Thanks so much! We called in to the dealership for service but they can't look at it until middle of September and we've got an October trip, go figure!
