Old 03-16-2015, 08:17 AM   #1
Grey Wolf 26rl
Water heater: when the bypass valves are open so that water enters the hot water tank, are the valves in line with the hose or are they sideways to the hoses. Please respond and thanks.
71ump is offline   Reply With Quote
Old 03-16-2015, 08:19 AM   #2
Toby's Avatar
when the valves are open the handle is in line with the hose. In bypass mode (for winter) the valve between the lines is open and the other two are closed. In normal use mode all are the opposite.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is online now   Reply With Quote
Old 03-16-2015, 08:22 AM   #3
fonzie's Avatar
Summer position...in-line with hose and by-pass (middle valve) perpendicular to line....
Name:	water heater bypass.jpg
Fonzie
grey wolf
