Old 05-14-2012, 01:53 PM   #21
BlakeB's Avatar
Originally Posted by cre10 View Post
I'm curious where the manual slide retract is too. I meant to ask last week but I forgot.
I have my 28BH sitting in my driveway right now and I crawled all underneath it, looked under the stairs, took apart the couch... I dont see one at all.
I have 2 cranks that came with the camper, one with a socket end (obviously for the awning) the other fits the stabilizer jacks.
Im not too worried about losing power as I can just plug the tow harness into my truck and it powers everything up... Im just worried down the line if the slide motor ever burns out.
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 05-14-2012, 01:59 PM   #22
cre10's Avatar
Your crank with the socket is for the electric jack. I don't believe the awning and jack have the same size socket, but I could be wrong.
2012 Chevy 3500 Duramax Crew Cab Z71 LTZ SRW
2012 Cherokee Grey Wolf 28BH
2011 F-250 6.2 Gas
2001 F-350 Powerstroke
1995 F-350 7.5L 460
Numerous Ford and New Holland Tractors up to 135hp. Bobcat 773.
cre10 is offline   Reply With Quote
Old 05-14-2012, 02:27 PM   #23
prof_fate's Avatar
I didn't get any tools for the awning.
My expy pulls the TT very well, seem to have sufficient power for whatever the road has thrown at us so far - in western pa we have grades to contend with - 8 to 12% ones. Never had any issues keeping up (55-60mph).
And power from the tow harness isn't likely going to be enough to run motors...and the usual problem isn't a dead TT batter but a motor that won't run for whatever reason so you need to manually retract the slideout.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 05-14-2012, 02:44 PM   #24
BlakeB's Avatar
I picked up my 28BH from storage (only there 4wks) and the battery was dead as a door nail. Couldnt retract the jack or stabilizers so I backed my truck up and connected the pin... everything instantly worked.
The F150 has a separate power source back there I found out. Mine had a fuse and a relay in the glove box that I had to put in under the hood. Ford does not install them from the factory because it supplies power to charge the battery on the trailer brakes (if the trailer has it). This stops the trailer if it comes unhitched. Some of the older trailers (of any kind) arent compatible with this and will blow the fuse. I know my 28BH came with a break away cable to just wrap around the hitch pin but a lot of trailers have that battery activated break away. Maybe this is why everything worked...not sure
Old 05-14-2012, 02:48 PM   #25
Dunefam's Avatar
I read somewhere on here that if you cut all the power (battery and shore power) You can just push the slide in. My dealer didn't have a clue either
Dunefam is offline   Reply With Quote
Old 05-14-2012, 02:50 PM   #26
prof_fate's Avatar
Not sure the amperage that it would put out would be enough to power much other than some lights - it's not a very heavy wire.
As to the battery on the trailer - it's what operates the brakes should it become unhitched when driving and a dead batt won't do that. Batteries need charged at least once a month or they'll sulfate and be junk.
2011 Grey Wolf 28BH
Old 05-14-2012, 02:53 PM   #27
BlakeB's Avatar
Like I said...worked ok for me.. stabilizers and jack went up fine
Old 05-14-2012, 03:04 PM   #28
cre10's Avatar
I think they were saying the truck power would not be enough to get the main slide to retract.
2011 F-250 6.2 Gas
1995 F-350 7.5L 460
Old 05-14-2012, 03:08 PM   #29
BlakeB's Avatar
Ya I wasnt about to try that with a dead battery
Old 06-05-2012, 12:06 PM   #30
BigTJohn's Avatar
There is no manual slide screw - BUT do not dispair, there is a very easy way to retract the slide. Just disconnect the battery and all power from the trailer, then just firmly push the slide to the stowed position. Reconnect - Again RECONNECT the battery as it provides the BRAKE which holds the slide stowed for travel. I looked ALL over the place for a manual retraction device, only when I spoke to the mechanic at the dealer did I find out this is the only way to manually retract the slide. I tried it today and IT WORKED flawlessly. Just don't try to "shove" the slide back in. Just steady pressure, maybe with a helper, and it just slides right in. This is a '12 Grey Wolf 26RL.
BigTJohn is offline   Reply With Quote
