Old 08-10-2018, 09:23 PM   #1
Grey Wolf - Location of Stabilizers
DW wants me to add crank down stabilizers to our new Gray Wolf 20RDSE that we purchased in May. We've been using X-chocks which have helped but she would prefer it be a little less wobbly.
Those of you who have longer campers with stabilizers, where are they mounted? Are they in front of or behind the triangular pieces at the back of the camper? Are they mounted to the I beam or to the tubular member that holds the bumper?
Thanks!
Rick
RickoMathis is offline   Reply With Quote
Old 08-11-2018, 01:01 AM   #2
Stabilizers should be attached to the main frame. The V irons are skids to protect the rear of the TT. I'm stunned you do not have four stabilizers factory standard.
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 08-13-2018, 08:57 AM   #3
MillMitch's Avatar
If they are on your TT, the rear ones will be right in front of that v bracket you asked about. If they are cranked up tight to the frame, you might not notice them. Front set should be almost at front of camper. They could be manual or electric. We have a different model grey wolf, but our crank was in the front pass through storage (probably 2-1/2 feet long) hanging in a plastic loop screwed to the front storage wall (that lasted about a nanosecond while camping).
Good luck.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 08-13-2018, 09:02 AM   #4
GOODBYE SUIT - HELLO RV!!
Rick
If they really are not there, that is a major oversight at the factory. If you do not locate them, call the dealership and have them send a mobile technician to install them. Stabilizers are standard equipment, not an option.
HAPPIEST WHEN CAMPING!
2019 Rockwood 2104s ****
2017 Starcraft Satellite 16KS
2012 Jayco X23B Hybrid
2009 R-Vision C243S Hybrid
2006 Coleman Bayside PUP
HappyCamper1962 is offline   Reply With Quote
Old 08-13-2018, 09:27 AM   #5
jd50i's Avatar
On a Grey Wolf, they are an option.
https://www.northpointrv.com/uploads...RP%2024830.pdf
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-13-2018, 11:59 AM   #6
WOW that is terrible. I've never owned a TT where stabilizers were an option! Like saying steps are an option!
Old 08-13-2018, 12:09 PM   #7
bikendan's Avatar
On some lines, the rear stabs are standard and front stabs are an option.
Equalizer WDH
Old 08-13-2018, 02:37 PM   #8
HDU
If it were me, I would mount them to the frame, as far out (away from the centerline of the camper) as possible. The further out and further away from one another, will provide more stability. I currently have a Gray Wolf 26RR with power jacks that pivot near the center of the camper, they work nice and are acceptable, but they are not as stable as previous campers I have owned that had stabilizers positioned on the outside perimeter of the frame.
HDU is offline   Reply With Quote
Old 08-13-2018, 02:52 PM   #9
jd50i's Avatar
I can't help with measurements but this should give you a good idea as to where they go.
2014 Grey Wolf 21RR
Old 08-13-2018, 04:14 PM   #10
My measures 11 inches from front of camper and rears measures 24 inches from rear of camper.
tmaxx16 is offline   Reply With Quote
Old 08-13-2018, 07:50 PM   #11
Bob43's Avatar
I added TWO more One on each side to my 26 RR just Forward of the wheels
Bob43 is offline   Reply With Quote
Old 08-14-2018, 07:32 AM   #12
Thank you all! Next question - are yours welded or bolted to the i-beam? Can I use self taping bolts or should I through bolt them to the beam?
Rick
2018 Grey Wolf 20RDSE Camper
2007 Toyota Tundra Crewmax
2008 Beagle
Old 08-14-2018, 07:34 AM   #13
Rick
Mine is bolted with self taping and bolts.
Old 08-14-2018, 07:40 AM   #14
Flybob's Avatar
Recommend you have a mounting plate welded to frame then attach the stabilizer to the plate with bolts. This makes it easier to replace one if it gets damaged or just fails.
Rick
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-14-2018, 11:21 AM   #15
Bob43's Avatar
That may be a good idea ... Didn't think of it so mine are just welded to the frame... sure hope they don't crap out
Old 08-21-2018, 03:01 PM   #16
cduemmel's Avatar
Only standard on TT equipped with slides. However this picture shows them installed.
Name:	20RDSE with Stabilizers.JPG
Chris & Susan
Greensboro, NC
2019 Grey Wolf 23MK Travel Trailer
2011 Ram 1500 Outdoorsman 4x4
2003 Harley Davidson Super Glide (solo seat)
cduemmel is offline   Reply With Quote
Old 09-08-2018, 04:42 PM   #17
cherokeewolf's Avatar
I have stabilizer jacks at all 4 corners. They do a good job but Im thinking of adding another set at the axle since there still seems to be a bit of roll when people are walking front to back.
cherokeewolf is online now   Reply With Quote
Old 09-08-2018, 06:12 PM   #18
Look into getting a set of the X-Chocks. It stops the movement of the tires back and forth when walking in the trailer.
katkt is offline   Reply With Quote
Old 09-09-2018, 03:16 PM   #19
I can't understand stabilizers being options on a Grey Wolf. I have a Wolf Pup 16BHS, no slides, and it came standard with four stabilizers. Granted, one rear is moved forward close to the single axle to allow space for the black tank slope, but there are four.
I have a set of old style Camco aluminum freestanding screw jacks I got for free from my BIL that I use one of behind the black tank on the frame to support that rear corner which happens to be under the bunks. Otherwise, the grandkids rolling over in bed shakes the whole trailer ;(
Old 09-19-2018, 03:11 PM   #20
Update - picked up a pair of BAL LoPro 5000lb 24" scissor jacks - worked great on first trip out - Mama is happy!
Thanks guys!
2008 Beagle
cat, grey wolf, location, stabilizers
