Old 05-16-2012, 10:40 AM   #11
BlakeB's Avatar
Originally Posted by stitchinsue View Post
How would I know if I don't have this vent hose? Besides looking, I don't know what I'm looking for. Mine is a 27bhks.
What putting this hose on will do for you:
1. Eliminate spilling freshwater while driving
2. Eliminate spilling freshwater while trying to level the TT
I dont ever travel with full tanks, but some campgrounds only have electric and you can fill up freshwater when you pull into the grounds. Thats great but if you have to go down a steep hill to get to your spot you will lose half your water before you get there and get level.
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 05-16-2012, 08:45 PM   #12
BlakeB's Avatar
Finished mine today...Great thread WhiskyJack! Here are some pics...
You can see the silicone good ol' Forest River just plugs the hole with (picks out easily)..
Also I had to take out some of the insulation in the hole in the floor..gotta get some tomorrow to spray in to plug it back up
ID:	13998   Click image for larger version
ID:	13999   Click image for larger version
Old 05-16-2012, 08:53 PM   #13
Whiskeyjack's Avatar
Good to hear!
Whiskeyjack is offline   Reply With Quote
Old 05-16-2012, 08:54 PM   #14
BlakeB's Avatar
Here's from the bottom... If you line the hose up correctly from the top it wont slip between the floor and the liner on the bottom of the camper..may take a few tries but works out good...
ID:	14004   Click image for larger version
ID:	14005   Click image for larger version
Old 05-17-2012, 08:09 PM   #15
Thanks for putting up the pics of the underside. Haven't had a chance to even look at the trailer this past week.
Old 05-17-2012, 08:19 PM   #16
Current River Rat
BlakeB,
Looking at your pictures it appears you have plenty of room to mount an accumulator tank at your pump. They really make a difference on pump cycling. In your second picture where the pump line goes into the blue cold water line would be a perfect spot for the tank. They are really easy to install. Mine, being a little smaller didn't have quite as much room and to shift some hoses around but it fit. I still don't understand their though process behind no vent hose. Just doesn't make good sense, except in their case probably cents.
Bruce & Sarah Tanner
Bttravel is offline   Reply With Quote
Old 05-17-2012, 08:20 PM   #17
vasnipe's Avatar
Blakeb - Good job on the vent hose route fix.
That last photo shows the one line putting a strain on the bottom tank sensor wire, not a good thing. You might want to reroute that line so it doesn't break the wire or make it come loose from the tank sensor.
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 05-17-2012, 08:57 PM   #18
BlakeB's Avatar
I noticed that when I was under there installing the new hose and it's actually got more play in it than appears in the picture. I will definitely keep an eye on it and may reroute it eventually.
Old 05-17-2012, 08:57 PM   #19
sundawg's Avatar
Accumulator tank? Where did you get yours and was it easy to install?
Paul, Marcia, Calyn, and Josie
2 Goldens- Asti and Ryan
1 Sheltie- Jackie B
2007 Expedition
2011 Forest River Greywolf 26BH
sundawg is offline   Reply With Quote
Old 05-17-2012, 09:07 PM   #20
BlakeB's Avatar
Originally Posted by Bttravel View Post
BlakeB,
Im very interested... Do you have pics? Or parts you used? Might be a good start of a new thread. Im sure a lot of people would be interested.
