Old 06-15-2013, 09:38 AM   #1
Question GreyWolf 25MB
I just purchased a 30' Grey Wolf 25 Murphy Bed. The Forest River Manual in some cases is useful, in others it is incomplete. For example, I want to change the keyless entry security code that comes with the manufacturer, and there is no indication on how to do it. Does anyone know who makes the keyless so I could possibly contact them for an instruction manual? Thanks!
greywolf is offline   Reply With Quote
Old 06-15-2013, 04:21 PM   #2
Greywolfdan's Avatar
I found it online. We are camping right now but when we get back I will post how to do it. It is at home in my laptop.
Greywolfdan is offline   Reply With Quote
Old 06-16-2013, 11:31 AM   #3
First of all, thanks for taking the time to reply while camping (hope you are enjoying your trip -- I can't wait for our upcoming trip too!). I did find some reference to Southco.com (which supposedly makes most of the keyless entries for TTs). I downloaded their manual and also received a reply from them within 24hrs. Let me know if this is the instructions you were referring to as well. Again, thanks for your quick reply! Enjoy.
Old 06-16-2013, 02:38 PM   #4
yes it is the Southco instructions. did they help you? if not this should do it.
Changing the User Code
The unit is shipped with a default user code of 1234, but can be changed
to a 3-7 digit number. To change the user code:
1. Press the 9·0 button for approximately 3 seconds. Keypad lights
should flash twice then stay on.
2. Enter the current user code. When entering the last digit of the
current user code, hold the button for approximately 2 seconds.
Keypad lights should flash once then stay on.
3. Enter the new user code. When entering the last digit of the new
user code, hold the button for approximately 2 seconds. Keypad
4. Repeat the new user code. When entering the last digit of the
new user code, hold the button for approximately 2 seconds.
5. Keypad lights should flash once then turn off. The user code has
been successfully changed.
If the keypad lights turn off during Steps 1-4, then programming has been
timed out and the process needs to be repeated from Step 1
Old 06-17-2013, 07:09 AM   #5
Yes those were the instructions sent to me. Thanks again for your help, this just confirms that I did get the correct instructions!
