08-27-2016, 12:27 PM
Greywolf 26 DBH
We own a 2016 Grey Wolf 26 DBH. I am interested in the type of slideout system that it uses and how to operate it manually if needed. I have read the Forest River Travel Trailer Owner's Manual and the Lippert Components towable RV Master Manual. Thanks in advance for any assistance on this topic.
08-27-2016, 07:25 PM
I'm not sure if the 2016 uses the Schwintek system or not, but my 2017 26DBH does. Here's a YouTube link for troubleshooting.
https://youtu.be/xojUdPDWNS0
08-28-2016, 12:26 AM
Well that was good to see. My 2016 DBH has a Schwintek. I better practice that and get a 2x4 to lock it in place. Now I wonder where that panel is for the slide? hmmmm.....
08-29-2016, 04:08 PM
2016 Greywolf 26 BDH Slideout
Thanks for the timely reply and information. My 2016 Greywolf 26 BDH does have the Schwintek system. Would anyone know the location of the Slideout controller?
09-01-2016, 06:40 PM
It is under the slide near the front. When fully in you can craw under at the bed and see it.
2016 Grey Wolf 26DBH
Ram 2500 5.7 Hemi 4WD
09-02-2016, 02:35 PM
Thanks everyone for your help! I have no slide problems but always want to be prepared!
09-27-2016, 10:28 AM
2017 26bdh
Taking delivery of our new trailer hopefully tomorrow we are so excited to have a slide and more room!!! I am diligently scouring this forum to learn all that I can!! Have a great day everyone!!
09-30-2016, 03:24 PM
09-30-2016, 03:50 PM
Who Dares, Wins
Had this leaking when my top slide seal was not sealing correctly. The water would run along the roof of the slide, down the side and onto the ground. I had the same pool and flow along the floor and to the rear bathroom area.
Depending on how hard it was raining, mine at least, did not have a slide topper so what is on the 10 x 3 slide will need to go somewhere when it is retracted.
That being said I also get a bit of a puddle when I retract in the rain but it does go away since it is only what was on the roof.
2015 Chevy HD D-Max
2022 Impression 315MB
09-30-2016, 03:58 PM
Same problem here. I'm told it's the top seal. I have spoken to several owners and seems to be a problem with this model. Suppose to take mine in in January for them to look at it. So long as the slide is out, no leak.
09-30-2016, 06:17 PM
I've got a 28dbud, and in heavy rain if the slide is open the entire time or closed the entire time, I'm dry. Bring it in during rain and I get a little water.
Also, I make sure the trailer is level or leaning to slide side if I have to retract in the rain the alleviate some of the moisture.
Sean
'16 28DBUD
'16 2500HD Dmax
09-30-2016, 10:29 PM
Who Dares, Wins
Within a year my top seal had completely come off from the side wall. The sealant they used did not bond to the wall which allowed my leak. The areas it was leaking was almost not even visible it was so small but it was there. I ended up redoing the sealant and all is well now.
2015 Chevy HD D-Max
10-01-2016, 09:35 AM
Ok awesome thank you for the input!! I have one yr warrenty so I may take to the dealer and let them figure out after we done camping in the few weeks!!
10-05-2016, 07:49 AM
Silicone
guys after reading through these forums I am terrified of silicone!! I resealed a couple little spots with silicone ( based on recommendation fromt the dealer!!) and now I am worried I am gonna have to go through and take out every place that is sealed and redo! I am 90% sure that silicone was used from the factory!!! Should I panic and redo immediately or can I just keep and eye on the seams and remove and replace with a different sealant as needed?? Also do you guys use a rubber roof cleaner and sealant at all? I am thinking of cleaning and sealing maybe twice a yr once at beginning of the season and once at the end of the season!?
Thank you so much you guys have been great!!!
10-05-2016, 12:40 PM
Who Dares, Wins
FR had something looking like geocel on my seams, no silicone. I used Sikaflex to reveal mine, also could have used geocel. No sickness for me. Without serious removal and cleaning nothing will stick to where it was or a year that remains
2015 Chevy HD D-Max
10-05-2016, 12:59 PM
Yeah I am going to remove and then clean and scrape...it my only options lol that's what I get for taking the dealers word and not coming here first!!!
I have heard good things about the geocel so that's what I am thinking I will go to! I am not going to do all at once though I am going to replace and remove as need which maybe soon by the sounds of it lol!!
10-05-2016, 01:01 PM
Had this same model in 2014 model. Never had that issue, so something has changed....
FROG AR-0019-242
10-05-2016, 01:13 PM
Maybe it isn't silicone but it sure looks like it!! Thankfully I only added a little bit of silicone around a storage flap and a little on the top seal of the slide because some of the other caulking was cracked!
10-05-2016, 01:30 PM
Doc one more dumb question if I use a geocel type sealant do I need to completely remove the older stuff I want to reseal or since it isn't silicone can I just clean and apply over this!?
10-06-2016, 02:29 PM
Who Dares, Wins
Sorry for the delay been training this week so very little service in the field.
I would take it all off.. Want a fresh start. I removed the bead along the top of the slide seal and caulked. It leaked, turned out there was a second separate wiper seal AND a bulb seal that I failed to realize was separate. Peeled everything off, sealed the wiper seal, was only stapled on... No kidding it leaked... Then sealed the top of the bulb seal.
I do not think it short cutted the first time around but still got a leak because I failed the realize it was two seals. I am now good to go.
I peeled off what I could then used a plastic scraper then last brake cleaning fluid worked the best to get off the residue. Probably not needed but then alcohol as a final prep before resealing. Did it over two days just to show how meticulous I was. Water sucks and does lots of damage so the time is worth it!
2015 Chevy HD D-Max
