Old 09-27-2018, 09:06 PM   #1
Hard wired under cabinet lighting on wolf pup.
Here are some pics of what Iíve done and figured out at the same time.
ID:	187697   Click image for larger version
ID:	187698   Click image for larger version
ID:	187699   Click image for larger version
ID:	187700   Click image for larger version
Peprice is offline   Reply With Quote
Old 09-27-2018, 09:08 PM   #2
More pics of undercabinet lighting.
ID:	187702   Click image for larger version
Old 09-27-2018, 09:14 PM   #3
So the process over the sink was to remove microwave first it is just held in with the 4 screws in the front and the plug. Then take out the divider. The thin board is just held in with small staples it pops right out. I tapped into the hood light with some 12 gauge wire and ran it to the center of the counter top so it was centered to the window. Really wasnít that bad.
Old 09-27-2018, 09:17 PM   #4
For the light above the table I did the same thing just ran power to the radio memory power and ground. Drilled some holes into the support braces in between the boards and thatís about it.
Old 09-27-2018, 09:19 PM   #5
This is how I tapped into the radio for power. Everything was soldiered then heat shrink tubed.
Old 09-28-2018, 12:00 PM   #6
K2Kevin's Avatar
Nice job. Range hood light/wires... where do the run? To the wall behind microwave?
K2Kevin is offline   Reply With Quote
Old 09-28-2018, 12:54 PM   #7
The range hood wires run into the wall directly behind it. The second pic shows it. I drilled a hole in the lower section of the cabinets close to where they go into the wall to run my wire.
light, wolf pup
