Old 09-29-2014, 01:11 PM   #1
Roll Tide
kennythornton74's Avatar
Heat strips.
Thinking about having a heat strip installed in my 15,000 BTU A/C unit to cut back on my propane usage with my furnace. Any positive or negative experiences regarding heat strips?
kennythornton74 is offline   Reply With Quote
Old 09-29-2014, 01:15 PM   #2
TURBS's Avatar
My boss has a heat strip in his mh and Altho it "works" it doesn't IMO work well.
Southern climates maybe ok but Midwest and northern climates not so much.
Turbs
Old 09-29-2014, 01:36 PM   #3
X2. In the best case they really only put out around 1500watts of heat which is pretty measly considering the cost compared to just a little $20 electric heater. If you dry camp much, also be aware that on average they draw something like 12-13amps compared to your furnaces 6 or 7amps. Even rougher is running it in tandem with your furnace to save propane. Then you're looking at a 18-20amp draw at times.
But to each his own. Having concealed, thermostatically controlled, ducted heat (if your not paying for the electricity) can be attractive.
rana is offline   Reply With Quote
Old 09-29-2014, 10:45 PM   #4
Who Dares, Wins
doc73's Avatar
We thought of doing this until I had read on here a review of the install and usage. They said it did well to just keep a chill out and not much else. I just use one or two space heaters.. Not my power. One larger heater in the center of the trailer makes it very hot.
2015 Chevy HD D-Max
2022 Impression 315MB
Old 09-29-2014, 11:41 PM   #5
GreenImp's Avatar
Send a message via MSN to GreenImp
If you have a place to put it, you may consider a built in single room forced air heater or two. These can be thermostatically controlled either on the device or remotely. I have considered this myself, but the 2 portable ones we already own just keep on ticking.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 09-30-2014, 05:56 AM   #6
cat1956's Avatar
We had one in our old camper and it would knock the chill off on a cool morning. It by no means will heat your trailer. The fan blows so fast that the heat is barely warm coming out.
Tommy and Wanda
2014 Flagstaff 27RLWS
2020 Ford F-150
Equal-i-zer 1,200/12,000 Weight Distribution w/ 4-Point Sway Control
cat1956 is offline   Reply With Quote
Old 09-30-2014, 10:09 AM   #7
RickV's Avatar
I started a thread about adding a bedroom ac to my 325res and at first I thought about getting one with the heat strip. After doing some reading I have decided against it. The 325res has a electric fireplace in the living room and we have a few space heaters we can use in the bedroom.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
RickV is offline   Reply With Quote
Old 10-02-2014, 01:25 PM   #8
Roll Tide
Thanks for the input everyone. I appreciate all of the responses.
