Old 10-05-2012, 04:46 PM   #11
Big Dawg's Avatar
I started the thread on the 2011 Grey Wolf. We had problems with ours, and as soon as we took it there, they knew it was an axle problem. They replaced both axles, and 4 upgraded tires. So far, things have been fine. The TT is going back to the factory at the end of the season (11/4) to have some other things fixed, and a fine tooth comb gone over the whole unit.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 10-05-2012, 06:24 PM   #12
Wanna Be Camper
SaskCampers's Avatar
There was a unit at the FROG rally in Goshen Lipert looked at and no questions asked replaced the axles and tires as well saying they were defective. I believe it was Nuiance's 2011 unit.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-06-2012, 07:28 AM   #13
BigTJohn's Avatar
I have a '12 26RL. I have weighed it loaded and everything is in spec. Trail Express 14" tires. Towed around FL about 1000 mi, no problems. Use TPMS, check psi every other fuel stop with handheld gauge. Just returned from 3500 mi trip to VA and back (lots of side trips) and had to swap spare for one tire. Inside edge was badly worn very concerned it would not make it the last 200 mi home (to dealer). Unit had been to CW for axle align 2 months prior (only 60 day warranty on that) as dealer had 6 wk delay and trip was imminent. Dealer now has TT and agrees tire wear is not right. Minor extra stuff - cracked vent cover, remote will not power up (new batt, will work by removing batt and reinstalling) hole burned in diffuser cover in range hood light. A leak somewhere in shower - not the drain, have remover the inspection cover and even the extra sawdust was dry. The leak always occurs after getting out of shower and seems to be behind the shower wall and exits at the bottom of the bedroom door jamb. Not a lot, 1/4 cup or less. I have sealed the wall and shower pan junction to no avail, also the h/c faucet plate. Will have to wait on dealer to finish, he called yesterday and has started. BTW I had same tire problem w last FR - same tire. Had to attempt to go through Lions Gate, FR does not do tires - Brenda (LG rep) said from pics it was not tires fault. Replaced with quality tires, my dime and all was well for last year of ownership.
Now I wait.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 10-06-2012, 08:14 AM   #14
Originally Posted by BigTJohn View Post
...Towed around FL about 1000 mi, no problems. Use TPMS, check psi every other fuel stop with handheld gauge...
Confused, if you have a TPMS, why do you check with handheld gauge? My TPS TPMS gives me a constant reading of pressure & temperature on the display on the windshield.
Old 10-06-2012, 02:10 PM   #15
BigTJohn's Avatar
Just because you have a TPMS which, as mine does, gives a "constant" (really a 3-7 min average) tire press and temp, does not mean one should rely solely on it. My TV also have TPMS but it only shows "Low Tire Press" warning, I have to check each tire to find out which tire it is and it only blows the whistle when the press falls to 28 psi or so. That is not good enough. I have 4 more sensors for the TV so ALL tires are monitored. I have had too many tire problems to just "hope it is all ok, my TPMS shows it is". I just like to be able to have a peace of mind feeling, and after all every other tank of fuel is usually a day and a half or so, so it is just checking, usually, each am before heading to the next site or CG. A little long, but now you know. You take care of your dive/parachute gear, it will take care of you. If you do NOT take care of your gear it will still TAKE CARE of you.
Brenda and John
Old 10-08-2012, 02:12 PM   #16
nuisance's Avatar
You are right, Leo looked at my tires and did a complete axle, tire and rim exchange. I was told that the production date was with in the range of the bad axles that they got from Lippert.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 10-08-2012, 02:21 PM   #17
Just because you have a TPMS which, as mine does, gives a "constant" (really a 3-7 min average) tire press and temp, does not mean one should rely solely on it. My TV also have TPMS but it only shows "Low Tire Press" warning, ...
Different styles evidently, the TST gives the actual temp & pressure, it cycles from tire to tire in a set sequence and takes about 1 to 1-1/2 minutes to complete the cycle. If a tire gets too hot or the pressure too low, it flashes the tire and sounds an alarm immediately. No way to independently check the pressure without taking the sensor(s) off.
