Old 03-31-2016, 03:47 PM   #11
Flybob's Avatar
There should be a small button on the resettable fuse ( you refer to as relays). Push the button. You should feel it click if it was tripped.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 04-02-2016, 09:21 PM   #12
Originally Posted by wmtire View Post
Are you currently connected to any form of 120 volt AC shore power?
Does any other 12 volt items work (lights, pumps, fans)?
There is usually a resettable "fuse" on your frame rail, just back from your battery that may have tripped.
There are some pics of it in this link, and there is a small button you push in on to reset it.
Battery Question
I would look now at the ground connection from the battery to the frame of the couch. Depending upon the house wiring, if the ground is inadequate nothing 12 volt will work. Even with the converter running off the 1:20
Tom48 is offline   Reply With Quote
