Old 03-31-2016, 10:51 AM   #1
nuisance's Avatar
Question Help! Urgent - power outage
Here is the problem.
No power to the following items: awning, slide, tongue jack, battery
We have removed the fuse for the slide and the red light did NOT come on.
We removed various other fuses and the red light comes on.
PLEASE help we leave to go home in 2 weeks.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 03-31-2016, 10:56 AM   #2
wmtire's Avatar
Are you currently connected to any form of 120 volt AC shore power?
Does any other 12 volt items work (lights, pumps, fans)?
There is usually a resettable "fuse" on your frame rail, just back from your battery that may have tripped.
There are some pics of it in this link, and there is a small button you push in on to reset it.
Battery Question
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 03-31-2016, 11:03 AM   #3
BamaBob's Avatar
What WMTire said!
- also check to make sure you have not inadvertently tripped your battery disconnect switch.
-- Also, also: check to see if there is a breaker/fuse in line with your battery disconnect. Has it tripped/blown?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 03-31-2016, 11:06 AM   #4
Flybob's Avatar
Also check the two higher current (30-40A orange or brown). If your battery was weak and you connected to 120V the charge current can be high enough to low these fuses.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-31-2016, 11:20 AM   #5
nuisance's Avatar
we have been plugged in since Jan. worried that the inverter might have taken a dump. fuses check out good
2016 Toyota Tundra
2011 Greywolf 26rl
Old 03-31-2016, 11:28 AM   #6
wmtire's Avatar
You may possibly mean converter (not inverter). Do you have inside lights that work, as that will indicate to us some things?
I would still check out the resettable fuse on the frame rail first.
Old 03-31-2016, 11:36 AM   #7
nuisance's Avatar
While checking for fuses under the tounge, Driver 39 found 3 relays. One checked out at 13.68 volts the other two 0 volts, looks like we go and buy 2 new relays . That may be the reason that the porch light won't go on either, changed bulbs and still nothing.
2016 Toyota Tundra
2011 Greywolf 26rl
Old 03-31-2016, 01:30 PM   #8
BamaBob's Avatar
Yep there is your problem Deb - usually those are resettable breakers though...
Old 03-31-2016, 01:40 PM   #9
nuisance's Avatar
a 12v - 30 amp fuse now just to replace it and see if that is the fix.
2016 Toyota Tundra
2011 Greywolf 26rl
Old 03-31-2016, 03:37 PM   #10
BamaBob's Avatar
What you don't travel with spare fuses?
(Harbor Freight - @ $6 for a nice assortment of RV fuses
power
