Old 07-24-2016, 08:45 PM   #1
Help with switch
Not sure what this one does. The one on the far right is outside light. The next one beside it is unknown to me. When flick it the lights in the trailer dim. That's it.
Sorry it a 2012 grey wolf by Cherokee. 28rbks
Lexa is offline   Reply With Quote
Old 07-24-2016, 10:07 PM   #2
2013leprechaun319dsf's Avatar
Do you have a storage area with a light in it?
2013leprechaun319dsf is offline   Reply With Quote
Old 07-25-2016, 06:13 AM   #3
Nope, not that I can see.
The one that my finger is on seems to be a master switch for the lights. Does that make sense?
Old 07-25-2016, 03:50 PM   #4
Do you have tank heaters?
Gotta go campin!
Old 07-25-2016, 04:20 PM   #5
That is a good question Bama. How would a fella know? Just bought this thing.
Old 07-26-2016, 06:50 AM   #6
dmacalli's Avatar
Although our Cherokee 274DBH has a different set up, one of the switches actually does control the main lights in the TT. With the switch off, none of the interior lights work, with the switch on, all of the interior lights work. It may be that...
2008 Toyota Tundra Crew Max
2016 Cherokee 274DBH
Calgary Alberta Canada
dmacalli is offline   Reply With Quote
Old 07-26-2016, 07:40 AM   #7
dmacalli, Thanks I will have to go and check that out.
Old 07-26-2016, 08:51 AM   #8
To see if you have heated tanks, look at the sewer discharge connector and see if you see any wiring wrapped around the pipes. If so, then you have heated tanks.
Gotta go campin!
Old 07-28-2016, 06:37 AM   #9
Looks like it is the main cut off for the overhead lights inside the trailer. Thanks for the replies.
Chris
2012 28 ft Cherokee Grey WolfBHKS
2014 F150 4X4 Supercrew 5.0 XLT XTR
Old 07-28-2016, 07:35 AM   #10
Mr. Dan's Avatar
Just a point about determining if you have heated tanks: my Wildcat has heated tanks but no wiring wrapped around discharge pipes/connectors. Mine only has rectangular heating pads stuck to the bottoms of the tanks. I could only see any evidence of tank heaters by dropping the bottom cover. There is no external evidence other than an unmarked switch inside.
Old 07-29-2016, 08:45 PM   #11
We have a 2014 Cherokee grey wolf with a switch like that one. One is for all the interior lights and the other is for the "porch" (outside door) light.
crgtin is offline   Reply With Quote
Old 07-30-2016, 12:43 PM   #12
Thanks crgtin
Chris
switch
