Old 01-02-2019, 01:32 PM   #1
HENG'S Range Hood Bulb Replacement?
Hello,
Have a 2017 Wolf Pup. Need a replacement bulb for under the Heng's Range Hood. Bulb appears to be 10w incandescent. Possible to replace with a comparable LED bulb? If yes, name of source/ part #?
thank you,
Ken
KenS999 is offline   Reply With Quote
Old 01-02-2019, 01:49 PM   #2
bob213's Avatar
Number of the current bulb would narrow it down quite a bit.
If no number than type of base etc.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is online now   Reply With Quote
Old 01-02-2019, 08:47 PM   #3
#912
Old 01-02-2019, 11:10 PM   #4
bob213's Avatar
Should be able to find it here:
LMGTFY
Old 01-03-2019, 09:11 AM   #5
Head Rambler
Just do a search for 912 or 921 LED's and you should find plenty. I replaced ours with a pancake LED and it works great.
Gotta go campin!
Old 01-03-2019, 09:37 AM   #6
Iwannacamp's Avatar
X2 it should be a 921 and my factory incandescent burned out in a matter of hours. Shoved in a led replacement I had bought for something else.. viola less watts, enough light and less heat. It looks a little blue, but who cares as I use it for a night light anyway.
2017 Puma 297RLSS
Old 01-03-2019, 09:40 AM   #7
Iwannacamp's Avatar
couple links..
https://www.amazon.com/d/Automotive-...s=921+led+bulb
https://www.amazon.com/Bright-Traile...s=921+led+bulb
2017 Puma 297RLSS
Old 01-03-2019, 02:44 PM   #8
D W
D W's Avatar
912 sounds about right. A 921 is 18 watts and may melt the plastic cover.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
1984 CHEV SCOTTSDALE K20 2GCGK24J0EXXXXXXX (Chevrolet Legends-Class of 2019)
D W is offline   Reply With Quote
Old 01-03-2019, 05:10 PM   #9
rlh1957's Avatar
LED Backup Lights are the answer
Here is what I put in my pitiful over stove light... The incandescent really didn't do the job, drew too many amps, got hot. I tried different LED's but just bright white and didn't do anything to illuminate the stove top. Then I tried a Backup Light. WOW. Now it is great for illuminating stove top and area, also great to leave on and have other lights off. Got it on Amazon. iBrightstar Newest 9-30V Super Bright Low Power T15 912 W16W 921 LED Bulbs with Projector replacement for Back Up Reverse Lights, Xenon White
Replaces 921/912 base bulbs, maybe others. Only about $13 for 2, but you won't be sorry if you want light, LED, low power draw and cooler operation.
Name:	Hood Light .jpg
ID:	193913   Click image for larger version
rlh1957 is offline   Reply With Quote
Old 01-06-2019, 10:27 AM   #10
I was able to pick up a package of 2 led replacements labelled 912 at Walmart for $15 thank you so much for all the helpful input. Ken.
Old 01-06-2019, 10:54 AM   #11
DAISY BOYKIN's Avatar
Range Hood
The wattage for the Hengs range hood is 5 WATTS.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
replacement
