Old 09-10-2008, 10:28 AM   #1
Run Forest Run
Hitch Weight
I am about to buy a Cherokee 30L and the Hitch weight is 680lbs compaired to the jayco I have now at 860lbs. Will the lower weight make it tow diffrent. For the better or worse?
J.J. King is offline   Reply With Quote
Old 09-10-2008, 10:37 AM   #2
dharri770's Avatar
I think its all about the ratio of tongue weight to trailer weight. I seem to remember reading the tongue weight should be about 10%-15% of the trailer weight.
If the ratio is the same, I would expect the Cherokee to tow very similar to the Jayco.
dharri770 is offline   Reply With Quote
Old 09-10-2008, 11:36 AM   #3
Head Rambler
As mentioned above it's all about the ratio. Even though the listed hitch weight is 680# I would bet that the real weight will be real close to what you're seeing now maybe even a bit heavier. The shipping weight on that unit is 7350# and 12% of that would be 882#. The GVWR is 10,850 so the TW if you ever reached that would be well over 1000#.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-10-2008, 02:08 PM   #4
Run Forest Run
Hitch Weight
The Diffrence between the two TT is only about 150lbs. Would that make any change in the way it pulls?
Old 09-10-2008, 03:14 PM   #5
Dodge Guy's Avatar
If that is the case, you`ll probably want to load more of your stuff up front.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
