Old 10-25-2018, 06:45 PM   #1
hot water heater
i have a 2018 wolf pup bhs. We had our walk through but we clearly did not retain the hot water heater part. we don't have any hot water...my husband checked the valves and they are open and we switched it on at the switch behind the panel outside. help! our last vacation was cold showers only. what are we missing here?
awdover is offline   Reply With Quote
Old 10-25-2018, 06:55 PM   #2
Bill and Gail's Avatar
How many valves are on the back of the water heater? If you have an outside shower, check to make sure both valves on the shower are closed, if they're open, it will act like a bypass.
Bill and Gail is online now   Reply With Quote
Old 10-25-2018, 07:02 PM   #3
wmtire's Avatar
Sounds like you have a Suburban water heater. User guide here:
Suburban's electric switch and much more
You may also have the winterization bypass valves incorrect. This thread will explain how you want them....depending on which bypass system you have
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 10-25-2018, 07:05 PM   #4
wmtire's Avatar
If this is your first RV, this thread may be of assistance:
New to RV's helpful hints
It has the above links in the previous post and much more.
Old 10-26-2018, 10:11 AM   #5
Commercial Member
ES_FR's Avatar
awdover,
First, thank you for joining the Cherokee family with your Wolf Pup purchase. Please accept our sincerest apologies for any inconveniences that have resulted from this lack of hot water. We encourage you to contact Mikala Yoder in our service department by visiting this personalized link: Forest River RV Direct Service Contact - Forest River, Inc..
In order to resolve your concerns as quickly as possible, please use this link and Mikala will respond within 24 hours.
Thank you,
Forest River
ES_FR is offline   Reply With Quote
Old 10-26-2018, 10:21 AM   #6
There are quite a few ways that the water heaters valves may be arranged. See page 2 of this generic plumbing pic.
2011 Traverse LT, 3.6L, FWD
Old 10-26-2018, 10:23 AM   #7
Mr. Dan's Avatar
X2
and "checked the valves and they are open" doesn't sound right. Wouldn't the bypass valve being open cause cold and hot water to mix and therefore lower the temperature of the mix?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 10-26-2018, 09:47 PM   #8
all that has already been said about the position of the bypass valves. also make sure the valves for any outside shower are off. you mentioned turning on the electrical switch on the water heater panel. by chance did you turn this on having water in the heater tank. if so, you may have, probably did burn out the electric heater element. you did not mention turning on the gas to the water heater. make sure there is water in the tank and turn on the gas burner valve. you should hear it come on and can easily see the flame if you stand in front of the burner. finally, go to the water heater and take the cover off. there should be two rubber covers about 1 1/2" in diameter. these cover the hi limit switches, press each of these in the middle to reset the hi limit switches. this is resolvable and you can heat the water with gas only, electric only, or both simultaneously.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 11-05-2018, 08:25 PM   #9
This might be too basic but if I understand correctly the hot water heater only runs on propane (at least that's how I think it works in my 2019), is your propane tank open and do other propane devices work (range, furnace)?
20vmki is offline   Reply With Quote
Old 11-05-2018, 10:44 PM   #10
wmtire's Avatar
20vmki, if the OP has a switch where they stated it was located in their OP (see comment emboldened in red above), then they have a Suburban brand water heater, AND this switch is to their electric heating element.
The Suburban SWDE and SWDEL models (gas and electric element) operation is explained in the link above.
You may want to check that out, and see if this is possibly what you may have in your RV too.
Old 11-07-2018, 10:08 PM   #11
Thanks very much for the feedback, I'll review my manual again that came with the water heater. I have the same switch, it sounds like, with propane OFF and the switch by the outside hatch ON, I should be able to get hot water?
Old 11-08-2018, 09:03 AM   #12
The answer is YES, unless you have an "L" model, in which case you will also have an inside switch which must be turned on. The L models have an inside 12VDC switch that closes a relay that applies 110VAC to the outside switch, so you need both switches ON. See wiring diagram below.
Name:	L Model 12VDC and 110VAC wiring together.jpg
If you don't have the "L" model, you won't have the inside switch or the relay, just 110VAC directly to the outside switch.
For both models, you'll always have the inside switch for gas.
Old 11-08-2018, 12:53 PM   #13
wmtire's Avatar
Rockfordroo, I like your schematic edits. Do you mind if I replace the schematics in my FAQ thread about the suburban water heaters with yours?
Old 11-08-2018, 01:28 PM   #14
Nope. Feel free to "shamelessly steal!"
Old 11-08-2018, 01:31 PM   #15
wmtire's Avatar
It's only stealing if I hadn't asked first.
Old 11-09-2018, 09:22 AM   #16
Just to follow up, my water heater running of 120VAC is confirmed, also, no internal on/off switch for electric mode, only gas on/off.
Thanks for the kind and informative replies!
Old 11-09-2018, 09:47 AM   #17
Denver To Yuma In 90 Days
Do you have a switch inside that looks like a light switch, but has a red light inside the switch (photo, switch at right and was NOT labeled from the factory)?
That might be the inside electric switch for the water heater...
In the photo below, the lighted switch at right on the white panel is the propane switch for the water heater.
These photos are from my 5'ver...
JohnD10 is offline   Reply With Quote
heater, hot water, water, water heater
