Old 05-17-2008, 10:01 PM   #1
Hot Water Heater
I just noticed this today and need a little information / advice.
I went to work on our Cherokee 28A+ stabilizer jack today. While working on it I could hear water in my hot water tank sloshing around. I decided to see how much water was in the tank so I removed the plug on the side and the had to be full.
After our last trip 3 weeks ago, I disconnected the city water line, flipped on on the water pump and then turned on both the hot and cold water values in the kitchen sink to drain most of the water. Should this have not drained my hot water heater tank?
What is the right right way to drain the hot water heater tank of most of its water when completing a camping trip?
Thanks,
Chris
Chris Gaskins
Austin, Texas
http://thegaskins.dyndns.org
2007 Forest River Cherokee Lite 28A+
2008 Ford F150 Lariat SuperCrew 4x2
5.4L / Auto Trans (Stock)
EAZ-Lift Weight Distribution Hitch and Sway Bar
cgaskins is offline   Reply With Quote
Old 05-17-2008, 10:27 PM   #2
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Unscrew the plug on the heater tank from the access panel outside.
Pull open the (over) pressure release valve.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 05-18-2008, 06:48 AM   #3
milzat's Avatar
Chris,
THIS VIDEO will show you how to drain water from the HW tank.
milzat is offline   Reply With Quote
Old 05-18-2008, 08:04 AM   #4
Originally Posted by milzat View Post
Chris,
Great video. Thanks for sharing that.
- Chris
Chris Gaskins
Austin, Texas
Old 05-19-2008, 11:38 AM   #5
The Jolly Mon
NDJollyMon's Avatar
Yea...I wish I had seen that when I started RVing! Nice one.
Pete (Jolly Mon)
cherokee
